11-29-2011, 10:03 PM | #1 |
trying to decide on either a 3" or 4" lift
I want to run a big 33" tire the toyo MT and probably 10" wheels to really give the 33x12.50's a beefy look. I have decided to go with tuff country ez ride all spring lift but can't decide on their 3" or 4" kit.
what do you think looks the best with a beefy 33" tire? I don't plan to ever run 35's although I love the looks of them I don't want the big power loss and strain on my trans and stock 10 bolt rear. Not to mention the truck has 3.42 gears and I want to avoid regearing to regain the power loss..I figure it should handle 33's a lot easier. I don't want the 3" if it chances the 33's rubbing either but from what I read it provides enough clearance. Trying to decide what will look the bet more gap or less. I will be using the tuff country ez ride all spring lit. Any suggestions or things to think about? that will help me decide? here is a couple pics as it sits now in stock form with 32x11.50s part of me wants to stay as is but I really want to move up to the 33's and clear them with ease. Last edited by weider1717; 11-29-2011 at 10:08 PM. |
11-29-2011, 10:56 PM | #2 |
I know the pieces fit
Re: trying to decide on either a 3" or 4" lift
A square over 33's clears easily and looks best, to me, with a 2.5" or 3" lift. The driveshafts and brake-lines will be fine and you won't rub 33x12.50's on 15x10" wheels. If 35's might ever be an option, go for the 4" lift.
11-29-2011, 11:05 PM | #3 |
Well said
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
11-30-2011, 01:00 AM | #4 |
Go 4". You'll wish you went bigger after a month... Hell my truck could clear 42's, but I want more lift and bigger tires...
Posted via Mobile Device |
11-30-2011, 01:07 AM | #5 |
Very similar thread here..
I'd say go with 4", thats what I've got & I love the stance...Heres a pic of my '87 K10 with 4" skyjacker lift kit, on 33" tires & 15x10 rims. It's got an auburn posi with 3.42s too, so we'll have nearly the exact same setup! However your truck is cleaan as hell man looks great! Good luck! |
12-22-2011, 06:26 PM | #6 | |
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
12-29-2011, 07:12 PM | #7 |
I have 3in easy ride springs all the way around with 33s and think it sits just right
12-29-2011, 09:02 PM | #8 |
My 33/12.50s don't rub and I have no lift. I wouldn't go with a 4" lift with only 33s. They look a little small I think.
12-29-2011, 10:19 PM | #9 |
I had a 4" with 33's and it made the tires look too small in my opinion, I'd go with the 3" but if the frotn looks low the 3 + 4 might be the way to go. In my opinion there's nothing worse than putting on bigger tires and having them look smaller.
12-29-2011, 10:22 PM | #10 |
78K & 79C Jimmys
Nice truck looks real clean
I've been wondering about it too,for the jimmy but thought you had to change more stuff going over a 3"
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-29-2011, 11:31 PM | #11 |
You must be on a 8" or smaller wheel? I was running 32x1150s bfg a/ts on a 10" wheel and they rubbed on stock suspension. Only off road but they would rub. I agree 33s look small on 4"s. But Im running 4"s with 35s and the front of the truckis lower than the rear witch I dont like.
Doug 66 4x4 GMC Suburban 76 4x4 Chevy Shortbed |
11-30-2011, 02:22 AM | #12 |
misshape grape
If you're gonna go 3inch, why not just go 4
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
11-30-2011, 09:55 AM | #13 |
Agreed, go 4. It's a sickness. If you went 3", a month later you would wish you went 4. 6 months from then, you would wish you went 6, so on and so forth. 4" is high enough but not radical. My next one will get the 4" and 35's treatment.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
11-30-2011, 10:23 AM | #14 |
Go 4 inch, just gotta jump a inch higher to get in the truck.
Like others have said if you go 3 you'll be wishing you went 4. BTW Wieder and Heavy87 nice trucks |
11-30-2011, 11:57 AM | #15 |
all excellent advice, and it answered my question will 3" suspension lit clear 33's on 10" wheels so the main thing is what stance do I want. I personally am leaning towards 3" that truck above looks great with 4" and 33's but it looks to have a lot of fender gap and I don't ever plan to run 35's Im just not gonna get into building the truck to handle that large of tire bc in stock form there just not engineered to handle 35's I think I'll be ok with 33's for what off road I will ever do.
leaning towards 3" at this time still not sure! bc the stance changes so much from 3 to 4. hard decision. |
11-30-2011, 05:29 PM | #16 |
I have a 4 inch lift and I think it is a little too high. I have a hard time getting things out of the toolbox and heavy objects onto the tailgate. I think it isn't worth the extra effort of making it higher.
12-01-2011, 02:00 PM | #17 |
I have an '83 with a 4" lift and I love the stance and the clearance. I have 33"x12.5x15 on a 15x14 rims. I have yet to find a place I can't get to, the only think I would add is a step to make it a little easier to got into truck on a hill. |
12-01-2011, 03:12 PM | #18 |
GoatLube Experss
go with the 4", we'll all like it better than the 3" !
by the way that is a really nice truck .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
12-01-2011, 04:22 PM | #19 |
4" w/35's on 16x10's
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! |
12-22-2011, 02:18 AM | #20 |
75 GMC 4" with 33s
12-22-2011, 03:17 AM | #21 |
Id say if you really do wanna run 33s do the three. i have a soft ride 4 and went with 35s cuz the 33s look small. this is 33s on a 4
12-22-2011, 04:45 AM | #22 |
Might do 4 up front and 3 in the back. I just ordered a set of 0 rate add a leaves for my truck from ORD. I dont like the front being lower than the back. May as well go ahead and get the ORD steering box kit while your at it if your planning on bigger tires. at the minimum you'll want the bolt on style to save your frame if its not cracked yet. I have both.
12-30-2011, 12:14 AM | #23 |
I have had a ton of these trucks and IMO the cleanest setup is a 2.5" or 3" and 33s. Rides the best, drives the best and "if" you ever wanted to sell it as clean as the truck is your "buying market" is a lot larger without a big lifted truck.
01-01-2012, 08:51 AM | #24 | |
02-13-2012, 01:40 AM | #25 |
Sorry, haven't looked at this post in awhile, it is a 10" with 38s.
