Old 11-30-2011, 06:24 PM   #1
rs72z
rs72z's Avatar
srw to drw spindle & brake ?
Ok guys time for some info.
I started to swap my srw 1 ton or so i thought over to drw today.
The question i have is did all of the drw spindles use the calipers that use one bolt and the slide on the bottom?
Mine has the two bolts like half tons do.
So is my truck not a 1 ton?
When i put the rotor on it fits but you can't put the calipers on with the pads.
Time for a spindle swap?
Paul
rs72z is offline   Reply With Quote
Old 11-30-2011, 07:55 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: srw to drw spindle & brake ?
The single wheel trucks have calipers like a 1/2 ton, with a larger bore piston. The dual wheel uses the large caliper with the retaining pin, as do all 1 ton 4×4's.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-30-2011, 08:32 PM   #3
rs72z
rs72z's Avatar
So should they work with the drw rotors or do i need to change spindles?
Old 11-30-2011, 11:43 PM   #4
ghettoluxury
If the caliper doesn't fit over the rotor with the pads in place you will have to replace the spindle for a dually spindle.
Old 12-01-2011, 12:43 AM   #5
pig rig
pig rig's Avatar
the dually spindle and the srw spindle are the same right down to the part number thats in the casting with out looking at a picture it almost sounds like you have a 3/4t spindle and the only diferance in the 3/4 and 1t spindls is the way the caliper mounts
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 12-01-2011, 08:29 AM   #6
rs72z
rs72z's Avatar
I'll get a picture later. When the rotor is on it almost touches the caliper mount, so it is probably a 3/4 ton.
Old 12-01-2011, 08:57 AM   #7
rs72z
rs72z's Avatar
So i decided to check the vin on my truck. It's turns out to be a 3/4 ton.
The vin tag says it's a camper special 8200 gvw.
So now i get to change the spindels also.
Will the 14 bolt rear pose any problems for the drw swap, besides needing spacers?
Old 12-01-2011, 09:10 AM   #8
SCOTI
SCOTI's Avatar
I have some stock 1-ton spindles.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
