Stirrer of the Pot
12 digit vin?
how do I decode a 12 digit vin on my '61 C10?
1961 crewcab
Re: 12 digit vin?
this should help:
http://67-72chevytrucks.com/vboard/s...d.php?t=316902
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Stirrer of the Pot
Re: 12 digit vin?
thanks for that its good info. the Vin on my registration doesn't fully match that... it does in some ways, but for one thing there is no letter "plant" designation. tonight when I get home I'll compare to vin on the cab...lol hopefully they are the same.
1961 crewcab
Re: 12 digit vin?
Is the "letter" for the plant a zero? 0, or "O" is for the oakland plant, which for some reason was omitted from that first chart.. we have it figured out on page 4!
![]() since you are in wa, there is a good chance that you have an oakland truck.
Stirrer of the Pot
Re: 12 digit vin?
no its a 6! lol
1C1446106529 |
Stirrer of the Pot
Re: 12 digit vin?
when I called the insurance company my vin gave them the correct details when they pulled it up... '61, 1/2 ton, etc. so I'm not concerned, just curious
1961 crewcab
Re: 12 digit vin?
might the 6 be an "s" for stlouis?, and been mis-written on the paperwork?
Stirrer of the Pot
Re: 12 digit vin?
maybe... i'm going to check the truck when I get home tonight. but when I read the vin off the registration over the phone to the insurance company it came up for them no problem... so IDK!
Stirrer of the Pot
Re: 12 digit vin?
on the cab...uh oh.
1C144L106529. so what kind of implications does this create for me? obviously somebody at some point swapped cabs? |
1961 crewcab
Re: 12 digit vin?
no, for some reason the L was replaced with a 6.....
too much else is the same for it to be a swap... and as we noticed, that spot should be a letter. I would check with a dmv in your state, without giving them too much info, explain what is going on.. you have a 61 chevy truck, that digit is supposed to be a letter (L), not a 6, all the other digits are correct, they can probably send a uniformed officer to re-inspect the vin and sign off on it, at worst you might have to bond the title, but since you have it, there is no worry of losing your bond.. that is how it would work here in mt, not sure if it will be the same in wa. ....
1961 crewcab
Re: 12 digit vin?
also curious that the "L" is the sixth plant down... wonder if the new car dealer and the dmv in 61 were assigning the plants #'s for the title for some reason.
Stirrer of the Pot
Re: 12 digit vin?
ha, I don't know how my brain did it, but last night I looked at those two vins and saw two different numbers, not just the L and 6.... geez.. must have been a long week! thanks for your help though, that makes a lot of sense. and yeah I think you're right, especially with the 6 vs L thing, would be interesting to see if anyone else has a similar vin scenario just for confirmations sake.
