Old 12-04-2011, 12:29 PM   #1
Horsman
Horsman's Avatar
1972 C20 Disc brake front hoses
Having fun trying to find the correct front brake hoses for my truck. I have purchased three different sets w/out success. The most current set purchased are long enough, secure to the caliper w/out issue, but will not secure to the frame properly.
I can push the line through the frame bracket, tighten the metal line to the hose ok, but the little push clips will not attach because the hose it not able to go through the frame braket far enough to get the clips back on.
My original hoses were trashed, I never thought I would have a hard time finding correct hoses for a Chevy truck.
If anyone has some originals they might want to sell, I would consider buying them and having them redone or if any one has run across this, I would like to hear their solution.
Thanks in advance.
Jeff Horsman
1972 C20 Highlander "C"
1966 Olds 442 L69 four speed
1971 Skylark (GS clone racecar) 494 stroker
1986 Buick T-Type
Horsman is offline   Reply With Quote
Old 12-04-2011, 01:21 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: 1972 C20 Disc brake front hoses
Where did you get the hoses? I wouldn't expect it to be hard to find either.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-04-2011, 02:28 PM   #3
Horsman
Horsman's Avatar
Several different vendors on the board, some were too short, others the ends were wrong. The best fitting thus far are from Brothers Truck Parts, but they still are not an exact fit.
Jeff Horsman
1986 Buick T-Type
Old 12-04-2011, 03:24 PM   #4
hdman6465
hdman6465's Avatar
Went through the same problem, no one has them. Brothers sent a pair. One was for discs, the other was for drums! Ended up making a pair out of braided stainless.
72 C10 suburban, lowered,nice original
55.1 Panel, bagged,old school
56 Panel,ls power,frame up build
72 C30 enclosed car hauler, 454,FI,4L80E
hdman6465 is offline   Reply With Quote
Old 12-05-2011, 11:01 PM   #5
Horsman
Horsman's Avatar
TTT...anyone else have any ideas??
Jeff Horsman
1986 Buick T-Type
Old 12-05-2011, 11:08 PM   #6
BuiltwithIvy
go to rockauto.com, never had any issue with stock replacement parts
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 12-05-2011, 11:24 PM   #7
Horsman
Horsman's Avatar
Thanks...tried their website w/out success. I think the 3/4 ton stuff is extinct.
Jeff Horsman
1986 Buick T-Type
Old 12-05-2011, 11:26 PM   #8
BuiltwithIvy
well, my last suggestion would be just make a frame bracket of your own, a small piece of steel, self tapping screws, and a drill bit, should be easy as anything else.
1930 Tudor Sedan
Old 12-06-2011, 11:23 AM   #9
Horsman
Horsman's Avatar
Something could be made I am sure, but wanting to keep the truck original as possible. As many of these trucks are around I am sure someone has found the correct hoses or has made some from originals. I wish I had not thrown my originals in the trash.
Jeff Horsman
1986 Buick T-Type
Old 12-06-2011, 02:11 PM   #10
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Have you tried In-Line tube? WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-06-2011, 09:48 PM   #11
Horsman
Horsman's Avatar
Their catalog has the same part number for 1/2 and 3/4 ton. They will probably be wrong also.
Jeff Horsman
1986 Buick T-Type
Old 12-06-2011, 05:30 PM   #12
flyingtim01
I got hoses for my K20 with PB from rockauto.com, I got some NOS Wagner hoses and they fit perfect. Maybe I got the last two? I'd keep checking with them and even give them a call, it seems like their inventory is pretty fluid and might change week to week.
flyingtim01 is offline   Reply With Quote
Old 12-06-2011, 05:43 PM   #13
Curt's_72
Curt's_72's Avatar
I just checked my receipt from when I replaced the front brake hoses on my '72 K20. The NAPA number is 36761. It was a direct replacement and is still listed with them. Hope this helps.
Curt's_72 is offline   Reply With Quote
Old 12-06-2011, 09:50 PM   #14
Horsman
Horsman's Avatar
I appreciate the info, but would the K20 be different from a C20 since the K's are four wheel drive?
Jeff Horsman
1986 Buick T-Type
Old 12-07-2011, 11:14 AM   #15
Curt's_72
Curt's_72's Avatar
I don't know if the hoses are different or not between C20 & K20. Those worked on mine, so you can compare those to your originals.
Old 12-07-2011, 11:01 PM   #16
Horsman
Horsman's Avatar
Ttt
Jeff Horsman
1986 Buick T-Type
Old 12-10-2011, 10:40 AM   #17
mbgmike
that part number does not show up with napa
mbgmike is offline   Reply With Quote
Old 12-10-2011, 10:46 AM   #18
mbgmike
Manes truck parts lists a 3/4 ton hose. they cost more than the 1/2 tons. You may want to call them and ask. I have used them and they are a great company to deal with
Old 12-11-2011, 11:06 AM   #19
Horsman
Horsman's Avatar
Have not ordered their's yet, I see they have a listing. I should call and see if they could send pics of the ends. Thanks!
Jeff Horsman
1986 Buick T-Type
Old 12-11-2011, 12:42 PM   #20
Curt's_72
Curt's_72's Avatar
Here's the link to the part I listed, NAPA 36761, that works for 1972 K20's.
http://www.napaonline.com/Catalog/Re...&Dk=1&Dp=3&N=0
Old 12-11-2011, 12:49 PM   #21
mbgmike
did not show up when i typed it in
I just checked again and it was because I had a c20 specified. it came up with 5 pages of hoses
Old 12-10-2011, 12:48 PM   #22
into69z
"brand new second-hand"
into69z's Avatar
i just check my NAPA receipt and I used part #36592 for my 69 c-20 with power brakes.
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 12-10-2011, 01:35 PM   #23
Classic Heartbeat
If you have the stock front end the 69 has drum brakes. The 71/72 is disk. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 12-10-2011, 07:11 PM   #24
mbgmike
I would just go get them made at Brakequip. here is n texas dealers
http://www.brakequip.com/maps.html
Old 12-06-2011, 09:52 PM   #25
earlthegoat2
earlthegoat2's Avatar
I put a 72 disc brake front end on a 68 a few years back and got the hoses from my local CarQuest parts store.
earlthegoat2 is offline   Reply With Quote
