Upper Radiator Support?
Hey all, been looking for an upper radiator support. They are hard to come by. I have found some for a 283. I have a 3 core aluminum radiator. Would this fit?
Easy Does It
Re: Upper Radiator Support?
i dont think they make repo. for the 60-66 trucks but the V8 version is larger, you could try the 67-72 upper radiator bracket
Thanks for the reply. I went ahead and purchased it. I figure I can modify it if it will not work. It looks like the right fit so I am going to push forward. I wonder why do do not make a reproduction? Brawley thanks again for the reply! Have a great week.
#4 | |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Nice fab work...looks real close to the original
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I have a 4 core aluminum and it worked for mine
![]() Join Date: Aug 2004
I think I may have one I wont be using, PM me and Ill get a pic for you.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
