12-05-2011, 02:44 PM | #1 |
Grandpa in the rustmobile...
Are these dimensions for lowering block for coil spring trucks correct?
Staying in FL in the big city found a spring shop that can make custom U bolts, I can get a pair for my truck for about $20.
http://67-72chevytrucks.com/vboard/s...d.php?t=196457 Found this link by TX firefighter. yours are messed up beyond recognition, tell the spring guy you need a pair of 5/8 thread, 24 inch long U-bolts for a 3 inch axle tube. He'll know what to do. TXFIREFIGHTER-I dont doubt you, I just wanna double check Thanks alot guys
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
12-05-2011, 03:39 PM | #2 |
67-72 parts collector,…
Re: Are these dimensions for lowering block for coil spring trucks correct?
I just measured the diameter of a stock u-bolt.
They measure .712" 5/8" = .625" 3/4" = .750" U decide which size you want. If Tx Firefighter posted it,... it will work!
12-05-2011, 04:41 PM | #3 |
I know, just seems like it was bigger. I appreciate it alot lolife!!!
12-05-2011, 10:20 PM | #4 |
ttt
