12-08-2011, 11:34 AM | #1 |
steering wheel questions
What wheels will fit my 62?
I purchased a 1965 impala steering wheel ebay thinking it would go right on but it didnt. I also see all kinds of older belair steering wheels that i lie but know if they will go right on. A little help would be great guys! |
12-08-2011, 11:42 AM | #2 |
It's Better With Nitro
Re: steering wheel questions
Do you have an aftermarket steering column? Most of the steering wheels of that era had the same spline spec.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
12-08-2011, 11:53 AM | #3 |
Its not aftermarket, the spline is the same but length of that splined metal part is too long and wont let it go down far enough. I sticks up to high and if I force it, then it pushes on the turn signal and they wont work.
12-08-2011, 01:49 PM | #4 |
Is that with the cancel cam?
Cuz if it is I think you can shave it. Posted via Mobile Device
X24 1964 chevy c10 step side 230ci straight six Auto power glide |
12-08-2011, 03:25 PM | #5 |
It's without it
Posted via Mobile Device |
01-06-2012, 11:52 AM | #6 |
I too have a 1966 impala steering wheel to be put on my 66 stepper. I haven't removed my current wheel to see if it will work yet.
steve'62 did you get yours to work? btw I have the factory column with the 3 speed column shift
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
01-07-2012, 09:51 AM | #7 |
you will have to shave the turn signal housing a little more than 1/8 of an inch and just keep checking, i found out the hard way when it started grinding the back of my wheel after i painted it. i was pissed!!
01-07-2012, 10:01 AM | #8 |
Thanks Blue Heeler; that doesnt sound like too much to take off. Will see
01-07-2012, 10:11 PM | #9 |
No prob.
