Old 12-08-2011, 03:01 PM   #1
K98AL
K98AL's Avatar
1962 Differential
New guy here - got a '62 LWB with 4 speed tranny, original posi rear end, and a 235. I'd like to keep the tranny, and change ratio on rear end, but the gear kits I've seen will only get down to 3:38 I believe.
With the granny tranny, I should be able to go to a 3 or 3:08 ratio without burning out the clutch.....so...
What's the best way to get that ratio? Are other gear kits available that I'm unaware of? Swapping entire rearend? How difficult is that?
BTW - I do plan on putting a lot of highway miles on.
Any help/ideas are GREATLY appreciated.
K98AL is offline   Reply With Quote
Old 12-08-2011, 04:29 PM   #2
1963c-10
1963c-10's Avatar
Re: 1962 Differential
Welcome to the forum, always glad to have new faces and pics around. Im sure some guys will pipe in to help you out.
1964 Short bed trailer
Old 12-08-2011, 04:37 PM   #3
Clyde65
Clyde65's Avatar
If your going from a 4.11 to a 3.38, that is a jump that should make a big difference I would think, also what size tires are you running? I am no expert at all, just regurgitating what I have read here.
Sorry bud, Welcome from Texas!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-09-2011, 01:25 AM   #4
Captainfab
60-66 Nut
To get a better selection of gear ratios, you are going to have to change that HO32 for a truck 12 bolt. The 12 bolt was first offered in the '63 model year. Any 2wd 12 bolt thru early '70 will be the same width as well as 6 lug. However, you will have to do some cutting and welding. The trailing arm mounts will need to be moved, and depending on the rear end you get, a panhard bar mount may need to be welded to the new rear end. The '63 and '64 12 bolts have the same panhard bar mount as your HO32.
Old 12-09-2011, 08:25 AM   #5
K98AL
K98AL's Avatar
Running plain 'ol 15" tires. Are the posi rearends in all the '62s 4:11? I haven't had the cover off yet, so I'll have to check that out. Thanks for the info, sounds like I have a project...
Old 12-09-2011, 05:31 PM   #6
Wrenchbender Ret
With a 235 I think 3.38 will be all you can pull. If you go to a 3.08 you are going to bog down on long hills & with that Granny type 4 speed, downshifting would be awkward.
Wrenchbender Ret is offline   Reply With Quote
Old 12-10-2011, 12:13 AM   #7
blackedoutharley
When we say "tire size" we mean the actual size or the actual diameter. Tire size can and does change effective gear ratio.
Going from 4:11's to 3.38's is like night and day and with a tall enough tire you may find you don't need 3:08's. or to go through the hassle of changing the entire rearend to get them.
blackedoutharley is offline   Reply With Quote
Old 12-10-2011, 01:01 AM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Although they don’t exactly grow on trees, another direct swap would be a Dana 44 from a 60-62 GMC. The ratios range from 3.08 to at least 4.11. There are two carriers. One covers from 3.08 to around 3.70. The other is required for the lower gears (higher numerically).
I agree with the comments above however. Going all the way to 3.08 with a six may be too tall a gear and cause the truck to run at an rpm that is below the torque curve of the engine.
And welcome to the forum!
Old 12-10-2011, 01:26 AM   #9
Captainfab
60-66 Nut
It has been my experience with the HO32's that the most common gear is the 3.90.
