Old 12-10-2011, 02:30 PM   #1
vegas80step
vegas80step's Avatar
Varnish on wood beds, how many coats under?
Hey guys, how many coats of varnish did you put on the back of the wood? I know a lot of you put 6-11,000 coats on the top... lol
But how many on th back side of the wood?
thanks for any info...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 12-10-2011, 03:15 PM   #2
vegas80step
Re: Varnish on wood beds, how many coats under?
So I should have put this in the General section huh? can some move? thanks...
Old 12-10-2011, 03:35 PM   #3
john_p
i recommend the same number of both sides.. same as outside furniture.. if the back can adsorb morns e humidity then the front, you get a bad warp.. bolted tight as the beds are, it shows up as a crack.. what are you using? i use the best clear deck sealer i can find.. follow the instructions and go at least three coats..all sides, including the ends
john_p is offline   Reply With Quote
Old 12-10-2011, 03:53 PM   #4
vegas80step
Thanks for the info.
I'm using Cabot Spar Varnish.
I was thinking 3 coats on back and sides would be enough to keep the moister out, with more coats on top for a shinny looks and UV protection.
I see your point, but do you think I would have that problem with 3 on the back and sides and 6ish on the front?
thanks for the help...
Old 12-10-2011, 05:09 PM   #5
S10Fan
Old Heap Driver
Don't forget the ends and edges.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 12-10-2011, 09:19 PM   #6
vegas80step
For sure... thanks for the input.
Anyyone else with varnish wisdom to share??
