Old 12-11-2011, 06:10 AM   #1
skidpan
drop spindles, and disk brakes....
I am bagging my 60 c10. My plan was to box the lower control arms, and pull the torsion bars. I'm about to buy drop spindles, but from what I can find I need to swap crossmembers, and suspension to a newer truck. I want to keep the 6 lug, and brake swap to disk shouldn't be a problem, but can I keep the stock arms? Will the torsion arm ball joints work with the drop spindles? I don't really want to have to change crossmembers, and arms, as I'm doing this on a budget.
skidpan is offline   Reply With Quote
Old 12-11-2011, 07:47 AM   #2
cdowns
cdowns's Avatar
Re: drop spindles, and disk brakes....
hope you know that the original 6lug steel wheels from 1960 normally wont work with disc brakes
Old 12-11-2011, 07:49 AM   #3
skidpan
I have a set of centerline 20s I'm going to run
Old 12-11-2011, 05:28 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
look at www.PerformanceOnline.com
They sell a 60-62 drop spindle for $229.00.
http://www.performanceonline.com/196...dle-Set-16683/
And a disc rotor that is drilled to the 6-lug pattern.
http://www.performanceonline.com/FRO...10-TRUCK-8600/
Keith
Convert to disc brakes.
Old 12-11-2011, 07:31 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
POL 15% off- coupon code CM11...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
