Old 12-12-2011, 10:24 AM   #1
RustySpoke
RustySpoke's Avatar
Rear five lug??
What are the options on changing the rear to five lug on a 65? There is plenty of info on the front, but I haven't found any on the rear?
I found a old suburban that has a 12 bolt and has 5 lug axles could those axles be a direct fit to the 65?
R. Spoke
RustySpoke is offline   Reply With Quote
Old 12-12-2011, 11:30 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Rear five lug??
You options are, but not limited too.. Finding a read diff from a 71-72 chevy truck. These are pretty much a direct bolt in. I believe CCP sells axles for the 65 rear diff, or you can bring your axles from the 65 to a machine shop and they can redrill them for a 5 lug. The axles in the later model diffs are wider by 3/4 a side. You can also just get 6 lug front rotors.
I searched and searched and found a 72 rear diff for $150.. Good ole craigslist..
This one is $329 and comes with Drums.. http://www.classicperform.com/Store/...k/6569RACK.htm
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-12-2011, 04:55 PM   #3
RustySpoke
RustySpoke's Avatar
Re: Rear five lug??
Thanks for the info.......since the axles are 3/4 in wider could I use the drums and brakes off of the suburban??
I am using the 73--87 complete susp. as I am on a budget and can't afford to buy too many trick parts.
Hey I was born in Alameda and lived in Hayward.
thanks again
Old 12-13-2011, 01:20 AM   #4
Captainfab
60-66 Nut
Re: Rear five lug??
You can not use the '71-'82 5 lug axles in the '63-'70 differential housings. The increased length will put the wheel bearing surface in the wrong position. If you have the complete 12 bolt from that Suburban, just buy a set of the trailing arm mounts, and mount it under your truck. But don't forget, you will also have to weld a panhard bar mount on the newer rear end.
If you decide to have your original axles plugged and redrilled, take a good look at the wheel bearing surface. If they are worn and/or pitted, it doesn't make much sense to put much money into them. You can get brand new 5 lug conversion axles for $275-$300.00.
thanks again
Old 12-13-2011, 11:47 AM   #5
mbgmike
Re: Rear five lug??
we sell the conversion axles from Moser Engineering FYI
mbgmike is offline   Reply With Quote
Old 12-13-2011, 10:03 PM   #6
RustySpoke
RustySpoke's Avatar
Re: Rear five lug??
Well I guess I might have to keep the 6 lug rear and do the 6 lug disc up front
Thanks guys for all the good info........I'm sure I will have more dumb questions sooner than later.
R.Spoke
Old 12-12-2011, 04:58 PM   #7
jimmydean
jimmydean's Avatar
Re: Rear five lug??
you can weld on perches to the 73 rear axle to use with your trailing arms, too. i am welding perches on a Caprice rear disc axle.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-12-2011, 05:46 PM   #8
RustySpoke
RustySpoke's Avatar
Re: Rear five lug??
what year caprice? and where are you getting the perches? that may be another option for me.
spoke
Old 12-12-2011, 06:09 PM   #9
jimmydean
jimmydean's Avatar
Re: Rear five lug??
'94 cop car with open diff from CL for $50. It's a little narrower than the stock, but I don't care. The perches you can get a lot of places, I was going to get mine from Early Classic.
<edit> The Caprice isn't as stout as the 10 bolt, but should be strong enough for my mild 327 build.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 12-13-2011, 09:03 PM   #10
pdxhall
pdxhall's Avatar
Re: Rear five lug??
I got my 5 lug axles made by Dutchman for $255 including studs installed. Very high quality.
pdxhall is offline   Reply With Quote
Old 12-14-2011, 07:20 AM   #11
brokenspoke
brokenspoke's Avatar
Re: Rear five lug??
I had a pair of 70 axles machined 3/4 inch off , remachining the c clip area....cost me 50 bucks
brokenspoke is offline   Reply With Quote
