Old 12-14-2011, 02:59 AM   #1
67 Burb
67 Burb's Avatar
Where's The Heat?
My 67 burb had good heat but only high fan if you pushed the air/fan lever hard to the right. Like a dummy, I pushed the lever too hard and I heard something go "CLICK" under the dash. I now have high fan OK, but now only cold air blows out of the heater and defrost vents. I realize the heat lever is separate from the air/fan lever, but something let go and I'm wondering where to start looking. After-market under-dash A/C has been added, so it is going to be difficult to get at the heater. Any hints? Thanks.
Bob
67 Burb is offline   Reply With Quote
Old 12-14-2011, 03:07 AM   #2
vectorit
What?
vectorit's Avatar
Re: Where's The Heat?
I'd start with the easy stuff.
Remove the climate control selector switch mechanism from the dash, and inspect all the levers and make sure they are still intact.
Then from there, inspect the cables to makes sure they are all still connected.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-14-2011, 12:01 PM   #3
OpelP1
OpelP1's Avatar
I have just made a repair on the heater lever in my -69.
The mounting that holds the levers to the chrome frame was broken so i could not move the levers enough.
But in your case some wires maybe has let go from the mountings, the levers are really close so the fan lever maybe has caused some some problem with the heater wire.
Chevrolet Suburban C20 -69, Pontiac Eight Fourdoor -34, Dodge Ram Quad 4x4 5.9 V8 2002, Opel Kapitän -59.
OpelP1 is offline   Reply With Quote
Old 12-14-2011, 10:14 PM   #4
67 Burb
67 Burb's Avatar
Thanks, guys. I'll start digging around under the dash. Either of you know if the heat control is a water valve or an air flap?
Bob
Old 12-14-2011, 10:43 PM   #5
vectorit
What?
vectorit's Avatar
Should just be a cable operated flap right from the control panel on the dash.
You most likely snapped one of the arms, does the heat lever move back and fourth easy now?
When you get under there, I recommend pulling the cables out from under the dash and either replacing them or let some light grade lubricating oil soak down into the sheath. Over the years they get dry and rusty, which makes operating the flaps hard on the selector arms.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 12-15-2011, 01:32 AM   #6
67 Burb
67 Burb's Avatar
The weird thing is - it was the air/fan lever I was forcing when something let go.
Don't have these problems with my old Chevy, though.
Old 12-16-2011, 07:52 PM   #7
67 Burb
67 Burb's Avatar
Well somebody had the air/fan cable switched with the heat cable on the control panel. Thats's why the heat disappeared when I was forcing the air/fan lever. To make a long story short - the heat cable was disconnected from the air door. Hooked it up and should have heat now. Just re-hang the A/C under the dash and try the heater.
Thanks everyone for the hints.
Bob
Old 12-18-2011, 10:38 AM   #8
OpelP1
OpelP1's Avatar
Your oldest Chevy looks very nice!
And the Burb too of course!
Old 12-19-2011, 02:20 AM   #9
67 Burb
67 Burb's Avatar
Thanks. That is my summer fun car. It's name is "The Beast" It has the original 1928 Chev 4 cylinder engine and drivetrain. But no top
Bob
heater controls
