12-14-2011, 04:34 PM | #1 |
Back-up lights
My '64 did not come with factory installed backup lights. Were these an option? I've seen them on other trtucks even earlier years. I'm curious to learn more about them.
I'm not sure it is all that important to me to have the correct lights especially beings I would probably have to put a toggle in to make them work (not sure if trans is equip'd with a backup/reverse switch to power the lights. I like the look of the single 4" spot as an alternative. I was wondering if anyone has examples or other suggestions.
1947 Art Deco Chevy truck 1964 C20 Custom cab 1965 Tempest Wagon 1967 GTO 1972 Luxury Lemans http://www.cardomain.com/id/a67goatnut |
12-14-2011, 04:38 PM | #2 |
Re: Back-up lights
I think they were an option, 1966 they were required. you have a nuetral saftey switch you probably have the reverse light switch.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-14-2011, 04:42 PM | #3 |
Re: Back-up lights
64 and 65 it was an option.in 66 it was manitory same with seat belts
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
12-14-2011, 05:27 PM | #4 |
Re: Back-up lights
I know they were an option on GMC trucks in 1960 and according to the sales catalog they could be fitted to all transmissions with a switch. see picture.
http://s1299.photobucket.com/user/jb...23904108567829 |
12-14-2011, 05:40 PM | #5 |
Re: Back-up lights
Reverse lights have been optional since the late 40s-I added them to both my 64s, I'm getting too old-- need them to back up w/o hitting things.
12-14-2011, 06:22 PM | #6 |
Re: Back-up lights
Does anyone know where you can get a new reverse light switch? mine went bad on me..
12-14-2011, 07:19 PM | #7 |
Re: Back-up lights
I picked up an new column shift NOS one from Ebay a couple of weeks ago. Great deal on it!
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
12-14-2011, 06:35 PM | #8 |
Check The Champ, Demonstrator
Re: Back-up lights
Reverse switch for an automatic or 3 speed manual are the same on the steering colum for a truck or car. The 4 speed switch is hard to come buy. There was a kit from GM for reverse lights.
12-14-2011, 07:41 PM | #9 |
Re: Back-up lights
I have a 3 on the tree. Ill have to look on ebay.
12-14-2011, 08:03 PM | #10 |
Re: Back-up lights
Switch is right in the middle of this picture.
1963 4 speed installation Last edited by aerotruk63; 12-14-2011 at 08:12 PM. |
12-14-2011, 08:11 PM | #11 |
Re: Back-up lights
is this everything you need to add back up lights to a 65? i really want to do it right.
12-14-2011, 08:24 PM | #12 |
Re: Back-up lights
There is an Accessory Installation Book you can buy which details the installation and shows you where everything goes and where to drill when necessary. These books are great when scrapyarding to get all the pieces needed. The rubber wedges in the picture are for 60-65 stepside. 66 had an embossment in the stepside fender.
12-14-2011, 08:28 PM | #13 |
Re: Back-up lights
thanks im looking for the fleetside. i have that book for the 65 i will look. thanks again
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 12-14-2011 at 08:30 PM. Reason: add |
12-14-2011, 09:38 PM | #14 |
Senior Enthusiast
Re: Back-up lights
01-12-2015, 12:46 AM | #15 |
Re: Back-up lights
03-24-2016, 03:17 PM | #16 |
Re: Back-up lights
I have a 64 C10 fleetside and a new set of aftermarket backup lights. What is the best way to cut the hole on the bed? Also, I just put in 1 new T5 transmission. It looks like it has the backup light switch already sticking out of the trans. What do I do to hook that up? thanks
03-25-2016, 08:26 AM | #17 |
Re: Back-up lights
03-25-2016, 09:23 AM | #18 |
Re: Back-up lights
Does anyone else have issues with their backup light switch/actuator setup? I actually had to bypass the switch with an on-dash toggle switch as the geometry of the switch bracket/actuating tab/shift column was always off and I could never get it to stay aligned.
'66 GMC K25 (305 V6, SM420) aka "Mabel" Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082 All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado |
12-14-2011, 09:50 PM | #19 |
Re: Back-up lights
I wish i could pull stuff out of the picutre
12-15-2011, 01:47 PM | #20 |
Re: Back-up lights
WOW, Great stuff!
I will have to look for and purchase one of those acc. install books. Aerotruck63, If it would not be to much to ask, in the meanwhile could you possibly scan the pages for the Auto trans switch install? Thanks for the help everyone!
12-15-2011, 03:10 PM | #21 |
Re: Back-up lights
Goat, sent a PM.
Jake
12-15-2011, 04:22 PM | #22 |
Re: Back-up lights
12-15-2011, 10:55 PM | #23 |
Re: Back-up lights
Is the locating template that is shown in the above pics from the accessory manual available? If not, someone should make them to assist in the installation.
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
12-16-2011, 02:24 PM | #24 |
Re: Back-up lights
corvettejim1968, Thanks for posting the install info. I really appreciate it!
12-21-2011, 12:28 PM | #25 |
Re: Back-up lights
OK, I'm closer to having backup lights. I found a complete set of originals that I will be installing. I have searched around for a switch but all of the switches that I have found have four spade connectors.
Any help locating a two connector switch would be appreciated.
