Engine Mounts?
I am getting ready to set in a mid 70's 350 in my 64. Correct me if I am wrong, but won't the 327 mounts work for my 350?
Also, I still go with a 64' trans mount for a TH350, right? Thanks for your help guys! |
Re: Engine Mounts?
Correct on both cases, note you will have to grind a little off of the trans crossmember in the front to access the trans pan bolts for sevicing......
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#3 | |
Re: Engine Mounts?
Also, I was looking at mounts from LMC and it seems they have multiplie mounts for the 327. This is a newbie question, but is there more mounts than beside the ones on the towers/perches? Thanks! |
Re: Engine Mounts?
New style crossmember ..no on the timming, and yes there are more than those there from other manufactures...just depends on who your going with. Your original `64 v8 mounts will work just fine. Just replace the upper rubber section against the block.
#5 | |
Re: Engine Mounts?
Thanks again! |
#6 | |
Re: Engine Mounts?
![]() Part number 34-0324 are the upper rubber sections against the block that get old and deteriorate, the lower section of the engine mounts will stay in the original holes on the crossmember, there are two sets of holes of which you would use the rear holes, or closest to the firewall.
