Rubber Floor Mat.
Anyone have these installed in their trucks?
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=120 (the polyvinyl) My truck came with carpet but I'm wondering about maybe putting this in instead of carpet because I have a feeling the carpet will stain after a trip to the deer lease. Would I need to cut holes for the seat bolts? If I use this, can i still use the chrome door sills? I like the look of them but I know the carpet fit under them. Thanks! Michael
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Re: Rubber Floor Mat.
I was going to order the same thing, but then I went with a new carpet.... Kinda wish I would have gotten the rubber.
You can use the door sills with the rubber mat.
I think these are the only way to go for a "working" truck. I'm yanking my carpet as soon as I save enough for a vinyl replacement. |
Moderator
![]() Join Date: Oct 2008
I've had seven trucks over the years with the factory rubber or vinyl and one with carpet.
I wouldn't get carpet for anything I intend to use as a truck. My 76 doesn't qualify as a working truck so it will get carpet. |
Does the rubber just sit on the flooboard with the seat bolts through it or does it attach anywhere else?
Moderator
I believe there was felt jute behind the rubber on all my squares to insulate my feet and soak up the mud once the floor covering wore through under my fuel pedal. I think the sill plates shifters and seat held it in place. My T400 GMC has Vinyl with Jute backing. The sills seat and shifter definitely keep it in place.
78K & 79C Jimmys
not the same but my 78 jimmy has the stock rubber mat front to back
everything is bolted on top of it,has the underpad or does yours go over the carpet too? i didn't like it at first.....but now i do it is cracked and dried out splitting here and there,like the spot at the pedals
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Hmm, it's my first truck but I work at the ranch alot with the cows and hunt at our lease all during deer season and when it's not hunting season that means it's time to get work done around there......and all of this means mud. From what I gather from my dad's truck is mud + carpet = big mess
I put the LMC pad in my crew just have to have it warm to get it to lay down and flatten after you roll it out I made the mistake of doing it in the winter and the shop was not warm it was a fight to get it to lay down I ended up just leaving it and will let it fall in when it warms up then trim the extra
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
I did the rubber floor in my '73. (ordered it through captkaos) Jute back under your feet, I put old blanket under seat area. Definitely make sure it's warm when you install it.
Door sills, seats, seatbelts, etc. bolt down the same as they did with the carpet. In an old snowplow, carpet wasn't going to work (IMO). The truck did have carpet from the factory.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
I ordered all my trucks new with the rubber floor mat (as did my father before me). Obviously a lot easier to keep clean than with carpet.
When I redid my truck I ordered the rubber from LMC but didn't like the fit (high hump floor) and sent it back. The one in my truck now is from Capt Kaos, which I would highly recommend. K ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
GoatLube Experss
![]() Join Date: Oct 2009
I'm gonna put a rubber floor in my car hauler and also replace the exsist'n rubber floor in my daily driver S10.
good to know the one CaptianKaos sell's is good quality. I hope he carry's it for a crew cab
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
