1961 crewcab
6 lug front disc brakes
so.. with dropped spindles you can't keep the drum brakes...
I do want to stay 6 lug to keep my wheels. saw a "kit" on ebay for $700 shipped that is the complete setup: spindles bearings rotors and calipers... wondering if it would be cheaper to source some of it from junk yards/ auto parts store.... I have a few camaro/transams that I could pirate some calipers off of. I had heard that you can just use 90's nissan/toyota 2wd 6 lug rotors from the auto parts store... anyone piece one of these setups together? got part #'s or suggestions? should I just save up and buy new?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
60-66 Nut
Re: 6 lug front disc brakes
Why not use the '88-'98 light duty C2500 parts. The conversion is described in the 'Dics Brake Upgrade Reference' thread. The parts to do it should be fairly easy to come by. This is what I will be doing to my Suburban........someday.
Isn't just easier to get some spindles from a '73 up C-10, with all the assorted hard parts and buy the 6 lug rotors that are offered in the kits from such places as CPP or POL?
gets board easy.......
67-72 parts collector,…
![]() Join Date: Nov 2002
I agree!
1961 crewcab
out of curiosity I wonder if the 6 lug rotors that are offered by cpp and others are the nissan/toyota ones?
No, they are stock replacement rotors that are drilled 6 lug rather than 5x5" (except the drilled/slotted ones of course).
From what I understand they buy the blanks before they are drilled 5 lug and have them drilled six lug instead. Uses stock replacement bearings, seals etc. Don't know if the wheel studs are 7/16" or 1/2' though. |
#8 | |
Companies like Early Classic Enterprises and Performance Online sell these. http://www.performanceonline.com/FRO...10-TRUCK-8600/ It's the easiest way to get 6-lug disc brakes. Add them to any 71-87 HD 5lug front suspension that originally came with 1-1/4" wide rotors. You can buy these rotors in "drilled and slotted" or standard plain rotors. Just remember,... your old Pre-'71 steel wheels will NOT clear the disc brake calipers. If you want steelies,... you have to use 71-87 6-lug 4x4 steelies to clear the calipers.
So dropped spindles and 6 lug discs will not work with my stock 63 rims? Are there aftermarket steel wheels that will work with the disc brake set up allowing you use the stock hubcaps?
great info guys.
im interested in keeping 6 lugs also. so... if i get the complete front suspension from a 73-87 with 1-1/4" rotors, all i have to do is swap the rotors with the 6 lug? everything else stays the same?
'66 chevy lwb c10 '65 chevy lwb c20 |
#11 | |
1961 crewcab
the wheels didn't look correct without the hubcap, but with the hubcap on you could hardly tell... The "windows" are a tiny bit different
Its worth $90 each to not spend my time racking my brain and cobbling something together from assorted vehicles.
Simplicity! |
1961 crewcab
yes that sounds simple.. now you are saying 71-87 "hd" suspension.. are there 2 different suspensions available with the 5 lug? and all I will need to do is measure the width of the rotor?
then I can just buy the new rotors? use the 73-87 control arms , and buy a set of dropped spindles for a 73-87, and then that should all bolt to my 65 X member?
#14 | |
Gm built a HD version (1-1/4" rotors) and a Light Duty version (1" rotors). I would skip the 73-87 stuff or 71-72 stuff unless you have a donor truck,... so you can rob everything, including all the steering components. Just buy 63-70 conversion spindles and BOLT them on. Change nothing else. No a-arm change. No ball joint change. No tie rod change. These conversion spindles ONLY come in the HD 1-1/4" rotor version that you need for the 6-lug rotors. You can buy these spindles every day for $229.00 at www.performanceonline.com.
#15 | ||
1961 crewcab
I will have some time to think about the options while I am saving up the $$ ![]() thanks.
#16 |
Hollister, CA.
![]() Join Date: Sep 2006
Hmmm....
I'm debating which way to go as well on my '63. Thought about the '88-'98 method, using 3/4 ton lowers to except the correct ball joints. I'm assuming these calipers off better stopping power (??) Then again, also thought about the '73-'87 a-arms for their rubber bushings... ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#17 |
I have this 6-lug disc brake set-up on my '69 swb.
#18 |
Another thing about "HD vs Light Duty",... everything has to match.
Spindle, rotor, caliper and bearings. They are all specific to the "width" of rotor that you are using. The 63-70 conversion spindles make it easy. (plus they even make a 60-62 spindle for the torsion bar trucks!)
#19 |
in my exp it is the rim to caliper clearance problem
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#20 |
Tot Roddin'
As Keith said, the kits take the guess work and prevent any return trips to the parts store. Ordered mine from ECE and only had to add bearing grease and brake fluid to the mix; everything was included.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#21 |
Garage Built Rides
![]() Join Date: Dec 2004
I recently purchased the McGaughy's 6 lug disc kit for my 65 from a local vender here in NM. It was a little over 700.00 with shipping and it came with the big rotors and calipers. Everything looked super heavy duty, nice parts. I'm starting to wonder about my 15" wheels clearing the caliper now too....
Albuquerque, New Mexico 65 long bed, shaved drip rails, tail lights, tailgate, and molding. 350/700r4, dropped springs |
#22 |
We swapped lower arms and spindles from a 84 burb, ordered the 1 1/4" rotors from CPP ( they were like $90 for both), bolted it all up. No worries since.
We had to make ab 15 trips to the parts store to find the right combo for the steering link but it was super easy. Posted via Mobile Device |
#23 |
If you look at the backside of an original drum brake wheel you will find the barrel of the wheel to be "rounded"... that is what causes the interference when installing on a disc setup.
6 lug wheels off of a mid 70's - late 80's 4x4 should clear and all aftermarket wheels will as well. |
#24 |
What wheel is that?
It's different than the style we are talking about. It won't accept a standard 1/2- ton hubcap. (no outside nubs). Posted via Mobile Device
#25 |
My bad, forgot about the standard hubcap. My wheels are 12 series smoothies 15x7. I have many choices of hubcaps to mount in the inside center and beauty rings but I left them alone.
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
