04-22-2003, 11:18 PM | #1 |
Under construction!
Hellwig rear anti-sway bar!
Brand-new---Fits 73-87' C10 trucks (Blazer/Jimmy probably as well) and includes instructions. It does need new washers/nuts for the axle U-bolts and new U-bolts. (I test fitted the bar and the nuts on the driver side U-bolt stripped out). It also will need new bolts (Endlinks) for the front assembly because Hellwig supplies crappy hardware. Otherwise, everything is there. I'm asking $65.00 + shipping OBO.
2001 Silverado bagged on 22's. *Sold* Last edited by BaggedC10; 04-22-2003 at 11:24 PM. |
04-23-2003, 12:45 AM | #2 |
Garage Queen Material
somebody buy this from him. he is a good busssisissis guy to do work with, and a rear bar helps out a lot. i have this exact same bar.
04-23-2003, 05:42 AM | #3 | |
Ocbaud,
I would like to but I have got to have a pic of it installed. What I need to know is where the bar is located in relation to the center of the rear end cover. I have a spare tire that just about hits the rear cover now. I think it has maybe 1" clearance. I know your truck is low and all but look at it this way, several people on here wanted to see your new bar, me included. Do us all a favor huh? LOLOL Quote:
04-23-2003, 07:06 AM | #4 |
i know i know i know....
my camera batteries are dead and we have no more double aa batteries here. i go to school at 6:50 in the morning and get home from work at 9:30 at night. i've been busy a lot |
04-23-2003, 09:45 AM | #5 |
rear swaybar
Hey Eric - yours is the exact same as the one LowC10 is selling... I'm guessing you got the one from swervin a while back, I remember you were wanting it pretty bad. Assuming that's what happened, was wondering about shipping when you got yours, cost etc. I'm guessing it would be close to the same. Also, my truck is not lowered, has the factory sway bar on the front. Any benifit from adding a rear swaybar on a stock setup?
Paul 1984 Chevy C-10 *LWB/305* |
04-23-2003, 12:58 PM | #6 |
Under construction!
The actual bar is like Mike's but Hellwig changed how they mount it. It does not use those large L-brackets outboard of the frame rail or J-bolts. The bolt (Endlink) bolts directly to/through the bottom of the frame rail.
2001 Silverado bagged on 22's. *Sold* |
04-23-2003, 02:34 PM | #7 |
Hotwheels?
Sent you a PM
04-23-2003, 03:08 PM | #8 | |
Re: rear swaybar
i flipped mine under the axle since my bed is so close to the axle since its lowered. I rear bar should help a lot with a stock height truck, but i dont know from personal experience. |
04-23-2003, 03:28 PM | #9 |
Under construction!
Also, Hellwig offers two different bars for our trucks---The only difference is the hardware. Being that mine needs new hardware, it doesn't matter what year or height the truck is. The actual bar is the same for our trucks.
BTW, thanks for the help Ocbaud!
04-23-2003, 03:45 PM | #10 | |
No biggie there dude!
Sorry you have such a tight schedule! I used to do the same thing. Hang in there 'cause in a hundred years no one will care. Quote:
04-23-2003, 04:05 PM | #11 | |
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
04-23-2003, 06:49 PM | #12 | |
Under construction!
Thanks but I apolagize for not dusting it off. Did you ever install it?
04-23-2003, 07:27 PM | #13 | |
04-23-2003, 11:03 PM | #14 | |
04-24-2003, 12:21 AM | #15 |
Just buy some rechargable batteries, then you won't have to wait so long next time unless you forget to charge them....
