12-21-2011, 11:40 PM | #1 |
Fuel Filler Neck
I am about to start my next "fix" on my '72 K2500. I am going to put a 31 gallon suburban tank between the frame rails in the back.
I would like to use a suburban/blazer-type filler neck. I want it to be in about the same position as the suburban in relation to the body lines. Has anyone done this? Also, where can I get a suburban filler neck? |
12-22-2011, 12:24 AM | #2 |
Re: Fuel Filler Neck
I got mine in the local pic a part.. Out of an 81 suburban. Took me 10 minutes to pull it myself.
12-22-2011, 12:34 AM | #3 |
What?
No one reproduces the Suburban 67-72 fuel fill pipe.
Salvage part only, and average cost I see usually is between 30 and 50 bones online. Though you could probably score one cheaper at a yard IF you found one.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-22-2011, 12:44 AM | #4 |
Isn't the 81 neck in a recess covered by a door?
