12-22-2011, 06:09 PM | #1 |
E-brake light comes on...
Is it normal for the brake light to come on when you 1st start the truck for the day and after that when i start the truck it doesnt?... Come to think about it there is no swicth at the e-brake pedal for the light. So what the....
Please chime in
'72 chevy k20 '06 H-D Springer softail http://www.bluemooncruisers.com/ http://www.enginecycle.com/ ~Eric |
12-22-2011, 06:11 PM | #2 |
Its a Truck Thing......
Re: E-brake light comes on...
Yep, all day long.... as long as its not on while driving, you ok...its for the hydraulic brake circuit and will stay on if there is a problem with the brakes.....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
12-22-2011, 06:57 PM | #3 |
the brake light is not for the emergancy brake in any way shape or form
brake light is for the hydraulic brake system when it comes on it means there is a pressure differental between front and rear brake systems
01-04-2012, 01:42 PM | #4 |
I have this issue too and thought it was the E-Brake light. How do I fix this correctly so the light goes off?
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
01-04-2012, 08:33 PM | #5 |
454 MAKES IT ROAR
There is a thread somewhere on how to wire up a switch to the E Brake so that it does use that warning light should you drive off with your E Brake on...a mod I must get round to doing as i'm always forgetting to release the E Brake.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
01-04-2012, 08:51 PM | #6 |
01-06-2012, 08:07 AM | #7 | |
454 MAKES IT ROAR
06-18-2012, 10:32 PM | #8 |
Hi, I did the e brake mod yesterday connecting a brake light switch to the e brake and to the warning light circuit. It IS very cool (and cheap) and it is something I would encourage any one to do. But my brake light has never illuminated during starting or at any other time, although my generator light would. In fact I worried my brake light had a bad bulb or a short. Unlike the post above, my brake light only comes on now when the e brake is depressed and only while the engine is running (In the mod it says it works whe the key is in the on position but not acc. Not mine, it only illuminates when the engine is runnng (??!!)). Must be similar trucks are not wired exactly the same. G.
06-18-2012, 10:40 PM | #9 |
Oops, forgot to add that to make the light go out you must re-center the proportioning valve. Known as "centering": either jam the brakes really hard or push in the pin that is covered under a rubber protector on the valve. With the pin depressed it will allow fluid to go to both front and back systems. This will equalize the brakes. At least you know you don't have a problem in the warning circuit! G.
06-18-2012, 10:51 PM | #10 |
How many miles have I driven with the e-brake on? I need to look at the <$50 mod to get that brake light TO come on with the ebrake!
06-19-2012, 10:24 AM | #11 |
It really is worth doing. My truck had the little braket on the e brake already, so all I needed to do was wire up the switch. The wiring diagram shows 2 tan (20T) wires going to the ignition switch, but my truck only has 1. I figure this is why the brake light only works with the engne running!
