12-27-2011, 10:24 AM | #1 |
16 gallon tank on a long box truck
Hey fellas, Here's what puzzling me lately. Lmc shipped me a gas tank last year by accident and said it would cost them to much to ship back and asked if I would keep it for free I said sure lol. Anyways its a smaller tank than the one that was on my truck i think my truck had a 20 gallon this one is 16 and a whole lot shorter. I got it hooked up and it fits and looks great, I'm just wondering where i would get a new filler hose as mines about a foot too short now. Did long box trucks have 16 gallon tanks ever?
Any help would be appreciated! Thanks! |
12-27-2011, 10:27 AM | #2 |
Re: 16 gallon tank on a long box truck
Long boxes with dual tanks were 16 gallons.
Posted via Mobile Device |
12-27-2011, 10:29 AM | #3 |
Awesome! think an auto parts store could order me up the hose or is it a special part lmc type deal.
Thanks for the hasty reply!! |
12-27-2011, 10:35 AM | #4 |
Just called partsource they cant get it. Does anyone know which part it would be in the lmc catalogue? It doesn't show a different part number for long and short box trucks. or 16 gallon tanks.
12-27-2011, 11:52 AM | #5 |
resident wrencher
Long box duals are 20s
12-27-2011, 12:03 PM | #6 |
chevy runs deep
my 87 long box came from factory with two 16 gallons tanks
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
12-27-2011, 12:05 PM | #7 |
x2 and my 84 4x4 came with 16s as well it had duals
Edited by staff |
12-27-2011, 12:55 PM | #8 |
12-27-2011, 01:38 PM | #9 |
i have yet to have to buy one but autozone, advance auto, or rockauto.com might have them
Edited by staff |
12-27-2011, 03:10 PM | #10 |
Napa sells a generic fuel filler hose. Measure both your tank and filler neck size first. They have straight lengths, and a few sizes with a 45º or 90º bend in it.
I'd get some pipe (exhaust tubing or copper drain pipe) the correct diameter and just cut the existing hose to extend it. Alex. |
12-27-2011, 03:43 PM | #11 |
resident wrencher
My stock 80 has duals and there both 20s maybe they changed them but i know that my buddys 77 had dual 20s and my 80 has them and my 77 had them
12-27-2011, 07:45 PM | #12 |
Don't order the fuel hoses from LMC. I love LMC and buy a lot from them but the hoses they sent me were about 6" to short. Checked the part numbers and everything.
I ended up going to O'Riellys and had to order a 15" 90 degree hose. I just did this yesterday and haven't installed it but I just have to cut and install.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
12-27-2011, 08:13 PM | #13 |
I put a 16 in place of a 20 and just cut the hose and clamped a pipe in there to make up the difference. Sorry cant remember the size it was some big truck rad piping i cut up. Also i've had long boxes with both 16 and 20s, got one of each i'm currently driving.
80 k35 3+3 DD (big dirty) 85 k1500 DD (scottsdale) and then a few more |
12-28-2011, 07:15 PM | #14 | |
12-28-2011, 07:29 PM | #15 | |
That filler neck website posted above would have been really helpful for me when I was getting parts. The 82-87 filler neck (part that bolts to the bed) is different from the 79-81 fuel neck which is also different from the one that came off your 78. Just look on that website posted above and compare the filler necks to the one you have. Then you can determine what filler hose you need. If I misread your post and you don't have a filler neck yet, then you should get those from LMC. I ordered an 84 filler neck and it hooked up to my 84 bedside just fine. The only bad thing was the filler/vent hoses because they were all wrong. note: if you get an 82-87 filler neck that works with your box it has a ground wire that needs to be grounded to one of the bed bots on the backside of your bedside. I didn't know this at first and was confused.
12-28-2011, 08:16 PM | #16 | |
12-28-2011, 08:36 PM | #17 | |
12-27-2011, 08:30 PM | #18 |
It also depeneds on the year of the tank. Different tanks had different size necks therefore need smaller or larger hoses. The newer tanks (82-87 I believe) have a 1 3/8" size filler neck while the older ones had a smaller size. Measure before you buy! lol
12-28-2011, 12:24 PM | #19 |
12-28-2011, 02:54 PM | #20 |
Thought my 76 had 1-16 gal. It had to be small I could never keep gas in it
12-28-2011, 03:53 PM | #21 |
Maybe you could order the wrong one from LMC and they'll accidentally ship you the correct one and you can keep it for free. Worth a shot, maybe?
Jay 1978 Big 10 Silverado, 355 + 700R4 + 3.42 + factory tach + A/C + dual tanks + working cruise control = awesome highway cruiser. |
12-28-2011, 05:17 PM | #22 |
Haha jay it's probably pretty likely it would happen!
Ok new question I found a hose that will work but now my bed rails are in the way is it possible that I have mounted the 16 gallon tank in the wrong spot? Can you guys see your sending unit between your box and cab with a 16 gallon tank? How close is the tank to the leaf spring hangars? Posted via Mobile Device |
12-28-2011, 10:00 PM | #23 |
Hey thanks for the replys! Dunno where you got the 84 and 78 years from? Its an 86 with the stock box (I should have specified) I'm pretty sure I have it mounted in the wrong spot now as the hoses don't line up now and when I mounted it I just used the normal back mount and just put 2 bolts in the front(cause they were the only ones that lines up out of the 4. now I'm thinking there are probably holes already drilled for this option and I used the wrong ones which means another afternoon under the truck lol. Does anyone have a picture of their long box truck with a 1 gallon tank on it?
Thanks for the replies "the 10" Sorry bout the year confusion I should have specified. |
12-29-2011, 01:39 AM | #24 |
Figured it out. I had it mounted in the wrong place. I had the tank too far back. I moved it and that solved the bed rail clearance issue. But now I've still got to track down a hose that will work!
12-29-2011, 11:41 AM | #25 | |
What I did for a temp fix, was to cut the hoses in half and use pvc pipe. That will work for awhile as the gas dosen't have to sit in them.
2017 Silverado LTZ 6.2 1984 Scottsdale K10 - 468 700r 4x4 lwb 1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb 1968 GMC 20 305 V6 good ole wood hauler. Good Fences make good neighbors |
