12-28-2011, 11:20 PM | #1 | |
"Oh well, it's a driver."
new to air tools
For Christmas I got a 100 psi pancake compressor. I've never had air tools before, and I have no idea what this thing is capable of. What are the limitations on a compressor like this? What essential tools should I get to go with it? I already have an air drill and a brad nailer. I'm pretty excited. Any input is appreciated!
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E Quote:
12-28-2011, 11:23 PM | #2 |
Re: new to air tools
linky no worky
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
12-28-2011, 11:27 PM | #3 | |
Yeah, fixed it. Not sure what happened there.
12-29-2011, 12:01 AM | #4 |
It will run any air tool just some of them not very long. We have one that we use on trips easy to throw in the back of truck or on trailer with generator. It is handy for airing up tires and using an impact to change tires and such but will not run the impact very long if you need more capacity you can plumb it to a 100 lb air pig and get more volume to run your tools longer.
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
12-29-2011, 02:31 AM | #5 | |
Hand Crafted C-10
Maybe a stapler & air ratchet. I like the siphon sprayers for spraying cleaner and the like. The brad nailer will do well unless used as a machine gun or on extremely hard woods. For the compressors health, try not to run it on miles of extension cord...the shorter (or none) the better. One good tip is to never place an airtool, that's still on the hose, on a bench or anywhere the hose can be tripped over. Disconnect around kids too. I've had umteen of the little buggers and love them! |
12-29-2011, 04:49 PM | #6 | |
Why is that? And thanks for the input!!
12-30-2011, 03:03 AM | #7 |
Son of a gun
The motor likes lots of amps to start and run on. Extension cords cut down on the amps delivered to the motor.
Bill BEATERS ARE NEATER |
12-30-2011, 11:50 AM | #8 | |
Good to know, thanks!
12-29-2011, 09:50 PM | #9 |
Three tools I use the most are:
1. 1/2" impact 2. 3/8" ratchet 3. Air hammer Posted via Mobile Device |
12-30-2011, 11:51 AM | #10 | |
12-30-2011, 12:19 PM | #11 |
01-08-2012, 05:18 AM | #12 |
Pancake compressors are more for low volume tools like a brad nailer, when just a quick shot is needed. This is why you seem them at construction sites. Tools like air hammers & 1/2 impacts will drain that very quickly. Which is why automotive shops employ compressors with big tanks.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
01-10-2012, 02:14 PM | #13 | |
For small jobs like light nailing, taking of wheel lugs with an impact, airing up tires, etc. you'll be okay, but that's about it. |
