Old 12-29-2011, 10:36 AM   #1
El Campo
El Campo's Avatar
Brake line size?
Getting ready to build some new stainless brake lines and was wondering what size of tubing to use. Is it 3/16 on the 72? Also anyone use the AN fittings and how did they work for you? Also if I convert to rear disc can I use the factory diameter brake tubing?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 12-29-2011, 10:49 AM   #2
JimKshortstep4x4
Re: Brake line size?
Stock brake lines on a 72 are 3/16" front, (master cylinder to the caliper hoses), 1/4" rear (from the master cylinder to a connection to a hose at the rear end location). On the rear axle the hose connects to a tee and from the tee to the brake cylinders, 3/16" line is used.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-29-2011, 11:29 AM   #3
El Campo
El Campo's Avatar
Thank you very much!
Hook em Horns!!!
Old 01-04-2012, 09:10 PM   #4
El Campo
El Campo's Avatar
Is there harm in building my back lines in 3/16? I read the other day that guys with rear discs sometimes have to rebuild their back lines down to 3/16 but will this push drums adequately?
Hook em Horns!!!
Old 06-14-2012, 02:36 PM   #5
Jules
Interesting thread man. I was just looking for answers for the same questions. One thing I noticed on my new parts is that the rear wheel cylinders take different size fittings and the rear hose that splits to the cylenders are both the same size. What's up with that?
Jules is offline   Reply With Quote
