Suburban Door Swap
We are thinking of going from clam shell to barn doors on the burban. Looking at the rear jambs it looks like all I may need are the doors and hinges and should bolt right in, is there anything I am missing? Will any barn doors from 60-66 work on the 65?
Just here to tinker
![]() Join Date: Jun 2008
Re: Suburban Door Swap
Pretty sure they are all interchangeable if you have the doors and correct hinges and latches. Be sure to hang on to those clam shells though, they are worth $$.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
60-66 Nut
As far as I know all you need is the '60-'66 cargo doors with hinges and the latches, and it should all bolt up. Although, you will have the notches in the tailpan where the tailgate hinges were. If you don't have the cargo doors already, you should be able to find some easily since most guys want the tailgate and hatch. In fact member Nobby is in the process of converting his from cargo doors to a tailgate and hatch. He has a build thread in the 'Projects and Builds' section.
Senior Enthusiast
My father in law did this swap on his 1960 Chevy Carryall back in the early 70’s. He hated the tailgate arrangement because it was the family car and made it difficult to load groceries. He had very limited mechanical skills but installed the barn doors without any problems in one afternoon. He just picked up the doors and hardware at the junkyard, brought them home and bolted them on. I can’t relay any technical details, but it must have been relatively easy or he would have completely hacked up the truck (probably with a torch) to make it work.
the notches in the tailpan get the plastic fillers you take off the hinge holes on the sides.
![]() Join Date: Feb 2005
Hey Bio,Look in the 66 parts section and search barns doors.I have everything you need.
PM me your number.
