Old 12-31-2011, 04:17 PM   #1
Car'n'Guitars
Car'n'Guitars's Avatar
Help Removing Carpet
How do get the rubber/insulation out that is under the carpet? Including removing the parts on the 4-wheel drive engage.
Car'n'Guitars is offline   Reply With Quote
Old 12-31-2011, 06:47 PM   #2
Mccoleman830
Mccoleman830's Avatar
Re: Help Removing Carpet
Just did my carpet set. My insulation came up with my carpet. I would start peeling off the insulation by hand. The 4-wheel drive trim should have screw holes around the perimeter of the trim.
1978 K-15, 350/350, 4.11's, 17" KMC's, 37's.
Mccoleman830 is offline   Reply With Quote
Old 12-31-2011, 07:17 PM   #3
Car'n'Guitars
Yeah thats what I thought too, but there is no screws or bolts on the 4-wheel drive trim so I don't to just go and rip it off and break something. Thanks for the help though.
Old 12-31-2011, 08:42 PM   #4
463
463's Avatar
in your photo: that black stuff that is the factory rubber (stock ) flooring. the red carpet remaining is a PO installed carpet. as for the 4X4 shift there should be screws holding it in place. the door sill strips have 4 screws each side. you would be a head of the game at this point to go ahead and remove the seat.
Trueman
463 is offline   Reply With Quote
Old 12-31-2011, 09:14 PM   #5
Car'n'Guitars
Okay thanks I new it was the factory rubber just didn't know what to call it thanks. I want the rubber out to see to passenger side floors and figure out what needs replaced, thanks and happy new year.
Old 01-03-2012, 01:01 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
mine has screws on the front/back edge
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-03-2012, 01:13 PM   #7
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
There are four seat bolts and two bolts holding down the seat belts on the floor. These go through the carpet so before you pull it out you need to remove them. The door sills also have screws through them and the carpet so you need to remove them also.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-03-2012, 03:58 PM   #8
Car'n'Guitars
Yeah mine was previously torn up so I didn't have to do all that. But I did get all the rubber matting out and the insulation. And so far I need 2 floor pans.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
