Old 01-01-2012, 09:13 PM   #1
earlthegoat2
earlthegoat2's Avatar
Front & Rear Full Suspension Tune Up
My 69 Chevy beater, which I was planning on just keeping as is as a work truck is turning into a project. Mostly because Im getting the tinkering bug and the all the bushings, ball joints, and tie rod ends are shot.
The previous owner said it was lowered 3 inches. Well it was more like 2 inches and it was not lowered. It is just that worn out. Or someone cut some coils out of the springs. Either way, after I get my Hurst shifter installed and the brakes squared away, the suspension is next.
I am only familiar with the kit offered by LMC. It is 500 bucks. Are there any other options out there for full on bushing, tie rod end, ball joint, springs, and sway bar mount bushing replacement kits?
earlthegoat2 is offline   Reply With Quote
Old 01-01-2012, 10:09 PM   #2
Stepper562
Stepper562's Avatar
Re: Front & Rear Full Suspension Tune Up
Stock replacement or Poly???
Stepper562 is offline   Reply With Quote
Old 01-01-2012, 10:25 PM   #3
earlthegoat2
Poly
Old 01-02-2012, 09:19 AM   #4
DugJones
I am looking at getting a full kit from Performance Suspension Technology (PST). They have kits starting about $200 and I read some good things. They just redid their site so everything isn't listed online, but I got some real good help by emailing them.
DugJones is offline   Reply With Quote
Old 01-02-2012, 04:09 PM   #5
robnolimit
robnolimit's Avatar
Bushings from PST or Energy suspension. As for ball jounts and Tie Rod Ends, get Moog or TRW. Most of the 'kit' ball joints and ends are not that great.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-02-2012, 05:32 PM   #6
earlthegoat2
That is the info I needed thank you fellas.
Old 01-02-2012, 07:30 PM   #7
hairlesshobo
hairlesshobo's Avatar
I recommend that you check out rockauto.com for the moog parts that you need. Most moog parts are between 20% and 40% cheaper than anywhere else.
Shawty: '84 C10 Silverado SWB, 700r4, SBC 350 - 4 bolt main, bored 60 over w/ Weiand aluminum intake and moderate cam, 2" true dual exhaust, Thrush mufflers, 3.42:1 gears -- Build Thread
The Tranny (wrecked ): '86 Trans Am, SBC 350 (now in above truck), Borg-Warner T-5, 2" true dual, Thrush mufflers, 2.73:1 gears
hairlesshobo is offline   Reply With Quote
Old 01-02-2012, 09:12 PM   #8
earlthegoat2
Thanks for the heads up. Looks like it might be cheaper going the route with the higher quality components. Or at least not much more expensive.
The steering and suspension is where I like to put my money most anyway.
Old 01-05-2012, 12:56 AM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Moog from oriellys
Wait, did i read somewere that moog is made in china, or was it raybestos?
John
1999 Toyota Tacoma 4x4
Old 01-05-2012, 09:14 AM   #10
hairlesshobo
I read that some Moog stuff is still here and some is China. As for which pieces are made where, I'm not exactly sure.
Old 01-06-2012, 10:18 AM   #11
chevyrestoguy
chevyrestoguy's Avatar
I just put Moog upper and lower balljoints in my '64, and they were all made in the USA. I swapped a '79 front suspension under mine, so all of my parts are for a '79. I price checked NAPA for the uppers and lowers, and their premium stuff was $192, including tax. I went to my local speed shop (Dale's Speed and Marine, Hesperia, California), and I got all Moog stuff for $154 out the door, tax included. It pays to shop around.
I priced Moog stuff on Rock Auto, and their prices are very good. I just wanted to buy local, so I went to Dale's.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
