01-03-2012, 03:50 PM | #1 |
Testing a Jumping Speedometer
Forgot to post this but i was having an issue with a speedo jumping on me at low speeds. I decided to do process of elim and figured out this little trick to bench test the speedo. I got a Q-Tip and put on end into a drill and put the other end of the Q-Tip in the back of the SpeedO housing. You can pull the trigger on the drill and test low mph all the way up to 75 mph (as fast as my 9.6v dewalt would turn) as a bench test. SpeedO was good, Turned out to be the upper cable. Hope this might help someone in the future.
85 Silverado SWB |
12-15-2012, 02:27 PM | #2 |
Re: Testing a Jumping Speedometer
Thank you.
12-15-2012, 03:48 PM | #3 |
Shot grease in my cable line and once it got lubed up no more waving.
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
12-15-2012, 07:12 PM | #4 |
I think that this is the issue with mine. You can hear it grinding likes its right behind the cluster.
12-16-2012, 10:55 PM | #5 |
Unhook.the cable from the speedo head and put a light oil down thr cable. Should loosen cable and smooth out the jumping needle.
Posted via Mobile Device |
12-17-2012, 12:09 PM | #6 |
I had that problem too...but mine turned out to be multiple speedos...I finally got one that works after replacing the speedo cable, greasing the new cable, and buying several clusters from pull a part lol
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
