Old 01-04-2012, 01:38 PM   #1
'70GMCStep
Wiring harness...plug and play?
Ordered some wiring harnesses for Christmas. Pretty much a plug and play deal, or is there some modifications to make?
(I've got the underdash main harness, engine harness, front harness, and guages harness that holds the dash lights)
Thanks,
'70GMCStep
'70GMCStep is offline   Reply With Quote
Old 01-04-2012, 01:44 PM   #2
1963c-10
1963c-10's Avatar
Re: Wiring harness...plug and play?
Pretty much plug and play. If trying to connect a new harness plug into an old one...sometimes that can be fun because the old plugs with heat and cold over time shrink or become brittle. Do the main underdash harness, guage harness then work your way forward. Also...doesn't hurt to order the new firwall grommets...only a couple of bucks but made a big difference when I did my new wiring. Use a little dawn and some water and they will install real nice. I did double check all the wires at the connects to make sure the colors match after finding a turn signal wire in the wrong place.
1964 Short bed trailer
Old 01-05-2012, 03:20 AM   #3
Iron-Butt
454 club
Iron-Butt's Avatar
Where did you get the wiring harness from?
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 01-05-2012, 09:24 AM   #4
'70GMCStep
Classic Parts out of Kansas City. I usually do business with them and LMC.
'70GMCStep
Old 01-05-2012, 09:28 AM   #5
1963c-10
1963c-10's Avatar
All my harness's came from Classis Parts. I converted from dummy light to factory guages in my 63 and replaced the harness for that reason. All went well except for finding 2 wires in the wrong places in the plugs for the turn signals. Check your plugs prior to install and you should'nt have any problems.
