01-04-2012, 02:18 PM | #1 |
suspension gurus - sway bars..
Thinking of running a splined swat bar/torsion bar in the front of my truck. One problem though, there's a million different rates.. Which one would be good to run? Starting point? Wanting something a bit stiffer than what a hotckis bar would be.. As I'm running not the stiffest spring in the world.. Any ideas?
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
01-05-2012, 08:52 AM | #2 |
67-72 parts collector,…
Re: suspension gurus - sway bars..
You might try sending a PM to member/vendor robnolimit.
01-05-2012, 11:11 AM | #3 |
I called speedway engineering and had those guys set me up with a bar that has many rates above and below it in the same size.
01-05-2012, 12:32 PM | #4 |
Try using a 1 1/4" dia. x 48 spline bar. Start with a .188 wall. once you have the mounts and arms fitted, swapping to a stiffer, or softer bar is easier. I use these a lot, but there isn't much room in the parts $$ wise. Go direct to Speedway Engineering, or www.1speedway.com they can help you out. - you can use normal, street friendly urathane to mount the bar.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
01-06-2012, 04:56 AM | #5 |
That is why I'm happy rob is here he knows his stuff well and more then helpful on anything.
