How about five on the tree?
Thoughts ond opinions on this please. Could it be done somehow? i like the t-5 swap idea but how about grabbing five from the tree? that would be cool imo.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Re: How about five on the tree?
Anything is possible with enough time effort and most of all money, however, occasionally money can be exchanged for extra time and effort!
The only way I can see this being accomplished would require use of a richmond 5 speed or something of the like with external shift linkages. Then with modifications in the column with an extra arm (or possibly two if you want reverse depending on trans used) and extra gates with springs so you could "feel" witch shift rail you are in like a floor shift, theoretically it could work. Unfortunately as cool as it would be to hide a 5 speed I am afraid the effort required to engineer such an operation would outweigh seemingly one benefit. Not to mention probably being really difficult to shift into the right gear. |
Omg why lol, 3 on the tree is terrible, but 5, you coudnt pay me to drive that
68 SWB Fleet 383 |
Couldn't agree more! Best thing I ever did to my truck was convert to the Hurst floor shifter. Have you seen how long & heavy that reverse/first shift lever is? No wonder they are clunky and wear bushings so quickly.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
if you put the clutch on the dash ?? like my baseball coach used to say "use both hands"
hey i know what rhymes five you cant drive
Maybe there could be a differnt way to accomplish the od trans on the colum has anyone put one of those gear vendors od system on the old 3 on the tree? how would that work and/or function is this possible hw about ground clearance? i havent seen or heard of these being used on this forum. ive been building my next truck in my imagination and really would like to keep a tree shift but all so have a od trans behind the i-6 to make a gas friendly classic dd
I am a Referee of life.
I think the GV is a great choice for this except for one thing.$$$ They tend to be pricey.Someone on here has done a GV or Atlas.IIRC it was a GV from a motor home.The adapter may be a bit difficult to find/machine but the gv only needs a toggle to work.I'ts probabaly cheaper and easier to do that than the 5 speed.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
I've been toying with the same idea here lately. I think it would be easier to use a Richmond five speed since it has shift levers on the outside of the tranny. Then, it would just be a matter of adding another shift gate to the factory column shifter. I'm sure it could be done, but I'm also sure it would require a custom made shifter mechanism. Do you have access to a machine shop?
49 Chevy 3100 69 Camaro Acro Sport II Biplane |
C/10 junkie
How about we split the difference and do a four on the tree with a 700r4?
![]() Posted via Mobile Device
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
sequential? Not cheap and bulky. http://www.ikeya-f.co.jp/en/product_...n_shifter.html
push button? http://www.secondchancegarage.com/pu...et-shifter.cfm dash mounted? |
You can't do it. The reason is that it won't rhyme any more. It has to remain three on the tree or three over the knee.
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
#15 | |
Vintage 4x4s
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#16 |
My brain is getting overloaded on this matter! what do!!!!!!
#17 |
I have been thinking of doing a 4 speed overdrive out of an ‘80s C10 and using my stock 3 on the tree. The shift pattern would be the regular H with 1st at the top left and all forward gears on the column. Then using a ’67 style parking brake lever (mines a ’72) make that lever actuate reverse. It would be a heck of a lot more fun to do the 1st to 2nd shift but I haven’t decided if the revese would be too much of a pain, you would have to go to neutral on the column then grab the sideways parking lever to go to reverse.
#18 | |
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
#19 |
If you're going to try it, do it to a tilt column, that'd be cool and couldn't possibly add any more difficulty to it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#20 |
I loved my three on the tree GMC, but I could not see having 5 on the tree....plus, as mentioned before, it won't rhyme...lol
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#21 |
Grandpa in the rustmobile...
I would be more interested in a detailed 4 spd car trans but use the 3 spd column shift. And a form of some kind for reverse lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#22 |
Interesting
#23 |
A friend has a 68 gmc 6cyl, 4spd on the tree. Blew up a couple 3spds , needed to jam something in it , put in a passanger saganaw 4spd , punched a rod throught the floor for reverse. Seems to work ok , planning on a little more gracefull reverse , maybe an electric solonoid.
#24 |
I seem to remember one of the very early Datsun or Toyota trucks had a four on the tree.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#25 |
When was looking at 3 on the tree info about a year ago I ready that in foreign countries, especially in cabs they continued to use tree shifters much longer than the USA and even included 4 speed & 5 speed trannys. It'd be cool to get some more info on those and even get my hands on 1 of those set ups.
I looked into the gear vendors also, thought about doing it when my carrier bearing broke. I was quoted $1000 for the o/d; plus I'd have to have the driveshaft shortened. The o/d has ears on both ends to connect to the yolk & driveshaft via u-joints. http://en.wikipedia.org/wiki/Manual_...ounted_shifter
![]() ![]() 71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
