Old 01-07-2012, 11:13 AM   #1
socalkevin68
socalkevin68's Avatar
Question glove box emblem question
ok ordered a new glove box "chevrolet" emblem for my 68 c10..and i'm wondering how it is suppose to attach?
It has three studs on the back side of emblem which go into the three holes on glovebox front..but no nuts to hold it on...and on further inspection the studs go into front but cannot be accessed from other side....does it come apart so i can attach the studs somehow or do i use adhesive?
just wondering the correct way...by the way the emblem was 25..and its cheap plastic..so if anyone has an orig i'd be interested..thx
socalkevin68 is offline   Reply With Quote
Old 01-07-2012, 11:55 AM   #2
kcsa75
kcsa75's Avatar
Re: glove box emblem question
There is a little clip (I know what they're called, but for the life of me the name is excaping me right now) that you push into the holes then push the emblem studs into the clips.
Swing by a body shop. They will have what you need. Otherwise, check LMC.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 01-07-2012, 11:58 AM   #3
bollybib
bollybib's Avatar
Silicone glue works and it's a lot easier than messing with attaching hardware. Just break off the studs and sand the back of the emblem flat first.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 01-07-2012, 02:01 PM   #4
sanford66
sanford66's Avatar
I believe they are called barrel nuts, check with a body shop. When i put the new one on my 68 i used double sided moulding adhesive tape. but i did leave the studs on the back of the emblem so i could install it in the correct location. It worked out ok for me. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 01-07-2012, 02:41 PM   #5
Hart_Rod
Hart_Rod's Avatar
NAPA carries the barrel nuts also.
Hart_Rod is offline   Reply With Quote
Old 01-07-2012, 03:17 PM   #6
socalkevin68
you guys are great..gona try to find barrel nuts..but wont i have to be able to get to the back side...there is like a cavity between front of glovebox and back and no way to get to stud to put on nut...
Old 01-07-2012, 03:45 PM   #7
leddzepp
Moderator
leddzepp's Avatar
the barrell clips push in from the front, you do not need to access the back as they do not screw into the studs.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-07-2012, 03:45 PM   #8
socalkevin68
thx
Old 01-08-2012, 10:02 AM   #9
Yeah,these aren't nuts at all. Just press fit,which makes removal the harder part. If you don't find these,silicone or weatherstip adhesive (my favorite) will work and there's no need to remove the studs.
Old 01-09-2012, 07:12 PM   #10
longhorn70gmc
longhorn70gmc's Avatar
Kevin,
Come over and I will show you how to do it and what to look for. I have mine off and can show you how when and where. I am here if you ever need any help my brother.
R/
Billy
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
