I'm just glad to be here!
Converting a 4x4 trans to 4x2
I have a chance to get a 2000 GMC 1500 4wd with a 5.3 and 4L60 trans for a really good deal. The frame is bent and the owner just wants it gone.
My question is what is involved with converting the trans to 2wd? OR would I be better off finding a 2wd trans and selling this one with the transfer case? THis will be my first swap to a 5.3 into my son's 82 we are building....
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Re: Converting a 4x4 trans to 4x2
You should just have to change the main shaft also known as output shaft to convert back to 2wd but a 2wd 4l60e should not be hard to find for cheap hopefully someone else can help
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#3 | |
It is not that hard to swap the shaft if you need too.. Yesterday I swaped a 2wd shaft for a special 4wd shaft. ![]() ![]()
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
It can be done, but since this is your first swap, why complicate things? Find a good 2wd trans and spend your time and energy on the actual swap. Biting off too much on a first time project is a recipe for getting burned out on the project before completion. Just my $0.02.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
meowMEOWmeowMEOW
^agree. If you were going to get a trans built, then it wouldn't really make a difference. You could just the new output shaft while its apart. Unless you find yourself needing a billet output shaft, finding a 2wd trans will prove easier.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Thanks guys. I do not think that I am biting off more then I can handle, heck the truck is all apart down to a bare frame. I just have a great deal in front of me for a complete running truck for cheap, but it is a 4wd. Once I have the truck and the stuff out, I will see what is needed. We are going to see how low we can keep the costs...
Let us know how you end up doing it. I just got a 4x4 4l60e on my donor and wondering about the same thing. I was in longview just yesterday too! If you take some pictures or find a good how to on the net I'd love to see it.
Gig'Em Kelly '12 |
I don't have the truck yet, going to try to make the deal on Friday. If I get it, I will add what we do either here or for sure in my son's build thread...
When tearing a 4L60E down that far.............Stab a new case bushing & Check/Replace the 3-4 clutches.
Thanks guys, I will keep all these comments in mind once I get the truck.
Tags |
conversion, trans, transmission |
