Old 01-08-2012, 12:43 AM   #1
S-31
Pics Of Exhaust on 60-62 with Torsion Bars
Does anybody with a 60-62 have any detailed pics of how their exhaust was run? I'm trying to figure it out on my 62 right now but it looks like the torsion bars and x member are gonna create problems. Thanks
S-31 is offline   Reply With Quote
Old 01-08-2012, 03:59 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Pics Of Exhaust on 60-62 with Torsion Bars
These terrible pictures are the best I can offer. All but the first two photos were taken about 15 years after installation so they were old and tired by this time. The torsion bar suspension was long gone, but these pipes were installed when it was still in place. The engine is a 350 SBC, and the truck is a 1960 short bed step side. The pictures jump around from front to back and side to side, so I’ve tried to sequence them to make the most sense. Everything was run as close to the centerline as practical from the rear T-Bar crossmember to the mufflers. This may not be the optimal layout but it worked without any rattles for many years before it was replaced with a really nice system:
The first two photos show the exhaust pipes up front were mounted inboard of the torsion bars:
These pics show the pipes after the torsion bar suspension was removed. They run parallel to the frame then pinch in just ahead of the torsion bar rear crossmember, nearly touching:
This picture is missing the T-Bar crossmember. All of these shots were taken just before the new exhaust system was installed, which is why the T Bar crossmember was removed.
Here is a close up looking forward just behind the T Bar crossmember:
And this is with the camera pulled back a bit for a wider view:
And these last two show the back end of the exhaust:
Old 01-08-2012, 04:22 AM   #3
bosephus
bosephus's Avatar
bosephus is offline   Reply With Quote
Old 01-08-2012, 04:31 AM   #4
bosephus
bosephus's Avatar
What kind of manifolds did you use with the tbars Markeb01? If they were headers what brand/pn#? By the way,that slave cylinder bracket is slick. I was wondering how to get rid of the iron b-housing on my 61 and still keep the hydraulic clutch. Thanks, Bo
Old 01-08-2012, 09:48 AM   #5
S-31
Thanks for taking the time to post the pics Markeb, thats what I'm looking for. I was thinking I might have to go outside the framerails, but the way yours was set up keeps the exhaust tucked up under the truck alot better.
Old 01-09-2012, 02:48 AM   #6
bosephus
bosephus's Avatar
The exhaust on my 61 is almost identical to markeb's except mine runs all the way out the back.Block hugger headers on mine(unknown make/on#)
Old 01-08-2012, 12:39 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
The manifolds are standard ram horn manifolds. The one on the driver side angles to the rear, but one that points straight down would probably work just as well. The first post in the following thread shows the same type manifolds I have:
http://67-72chevytrucks.com/vboard/s...haust+manifold
Post #2 on the following thread shows how I did the hydraulic clutch when I swapped back to a manual 4 speed:
http://67-72chevytrucks.com/vboard/s...slave+cylinder
The slave cylinder I have is an earlier design, but I'm sure the current production version works just as well. Here's what my earlier model looks like:
Old 01-09-2012, 02:50 AM   #8
bosephus
bosephus's Avatar
Thanks for the info!
Old 01-09-2012, 11:16 AM   #9
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Pics Of Exhaust on 60-62 with Torsion Bars
Wish I had pics of the with Torsion Bars before the swap.
It did make things tough..
Here are pics with the Mustang II IFS Clip to give you an alternate view.
X is out....
Ford 9" Rear....
Mufflers are home made.
And she's low on the ground...
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-09-2012, 11:27 AM   #10
1Bad62Pro/Street
More pics...
Old 01-09-2012, 02:10 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Mine is like markeb01, but dumps out before the rear wheels.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-12-2012, 08:51 PM   #12
S-31
1bad62pro/street: Are those the same headers you were running when you had the torsion bar suspension?
Old 01-12-2012, 10:41 PM   #13
1Bad62Pro/Street
Nah,
Actually the ones I had on there is still hanging in the shop.
I had a screaming 283CSB block at the time in her and lowered in the front as far as she would go.
The ones I have on there now are for a 1970 Chevrolet Corvette.
They are 1970 Chevrolet Corvette Hooker Competition Headers.
1969-1971: Base; 8 Cyl 5.7L;
http://www.jegs.com/i/Hooker-Headers...rentProductId=
http://www.summitracing.com/parts/HO...ry=Year%7c1970
http://67-72chevytrucks.com/vboard/f...play.php?f=117
Fayetteville NC members: Where U at?
http://67-72chevytrucks.com/vboard/s...d.php?t=368996
Old 02-07-2012, 09:30 PM   #14
S-31
Bringing this back up for more pics if there are any more out there.
Old 02-08-2012, 07:55 PM   #15
MusicMan70
MusicMan70's Avatar
pics from my Suburban's underbelly; duals on a 305 V-6 and AeroChambers and x-pipe; now if I can just get the underside as clean as the exhaust.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
