01-08-2012, 07:55 PM | #1 |
1987 issues / Help Please
Im in the process of my first 87 swb re-build. 1st issue is with the engine. I put a Comp Cam (268) in an otherwise stock 350/ TBI set-up. Do I need a E-prom change ? Having idle issues.
2nd question.... Have located a rear end from a 1990 454ss. It is supposed to be a stock application 373 posi. What issues will I face trying to install into my 1987 ?? Thanks in advance for any help !!!! |
01-08-2012, 11:01 PM | #2 |
Re: 1987 issues / Help Please
This should help with your cam selection. http://www.tbichips.com/truckmods.htm
The rear axle will have a different spring perch width and shock mount location, not a direct swap without welding/modification.
1981 Dodge D-150 (under construction) 2007 Chevy Suburban 2010 Dodge Charger R/T 1980 Kawasaki KZ 440 2004 Harley Sportster 1200 |
