need a little help regarding paint color
Hi,
Looking for a little help regarding the color of my truck. When I look at the info on the inside of the glove box door it lists the color as "special". However, when I looked through the glove box, I found the original order sheet and spec sheet for this truck and it lists the truck as being ordered maroon which it currently is. My question is this: Does anyone know what is meant by "special" and it alos appears that the firewall and door jambs are a goldish, silver color. I want to believe that was the original color and perhaps the truck was repainted (since the trim has been removed and the holes filled) but all paperwork says it was maroon originally(or vermillion to be technical). Any thoughts as to what may be going on here?? |
![]() Join Date: May 2009
Re: need a little help regarding paint color
My guess is that the Vermillion (paint code 515) is original and the cab has been swapped, based on what you've posted.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
Not sure. The factory vin number that matches the title and the id sheet in the glovebox match what is written on the firewall....looks factory to me so I am more confused now...
Posted via Mobile Device |
![]() Join Date: Dec 2006
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
