pros and cons 5 lug and 6
I have drop spindles for my 60. I plan on going to disks as required, but I'm not sure and can't decide if I should stick to off the shelf consumeable parts and swap to 5 lug, or order the rotors and swap to 6 lug. Which is more affordable? Wheels aren't really an issue, ill run either 6 lug 15 inch steelies, with wide whites, or dodge steel 20s and fill the holes. I know 5 lug rotors are typically cheaper than ordering 6 lug, but what about the cost of swapping the rear end to 5 lug? I know this has been covered in tons of pages of posts, I just wanted to know your view on my problem. It's late and not much is moving on the forum tonight, help a brother out...
Posted via Mobile Device |
Re: pros and cons 5 lug and 6
I'll tell ya my logic!
I am going to buy the 6 lug rotor's when I buy mine-I rebuilt my rear end and brakes so the 6 lug rear is like new. If I stay with 6 lug fronts I only need 1 spare. The disc brake wheel will fit on the rear 6 lugger.Just my OP I could be wrong |
Yeah, the stock 6 lug steelies don't clear the calipers. So you need to get wheels from a truck that had disc brakes. Personally, I am gonna stick with 6 lug when I do the disc brake swap.
I got my stock 6 lug steelies are from a 74 blazer 4x4, will clear the disk brakes and retain original trim rings and hubcaps. With the caps on, you can hardly tell they aren't the stock three bump wheels. The holes around the rim are a little different, but who cares? I believe 71-78 4x4 trucks, blazers and jimmys and some g20 vans will provide the rims.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#5 | |
I'll get some pics tonight for you. Have 5 in my living room already blasted and sitting in primer, so that'll make pics easier. Can show the backs too. Are you looking for the rims or hubacps to finish off yours?
C/10 junkie
I plan on sticking with the six lug front. I'm running the rally wheels. So my stock steelies on my 68 will not work with disc brakes??
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
Not mine.....good buy on slots here...
http://sacramento.craigslist.org/pts/2791984640.html
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#9 | |
C/10 junkie
Senior Enthusiast
If you don't care about running 5 spoke mags, I'd suggest it's cheaper and easier to stick with 6 lug rotors. Yes the rotors are more expensive, but how often do they ever need to be replaced. Having the rear axles redrilled, the center hubs machined down, and new drums are going to cost a lot more. As noted above, if you run 6 lug disc brake wheels with stock hubcaps - only a real enthusiast will be able to detect they aren't original.
Okay cool, thanks.
I'm looking for 2 of the rims. Look like this: ![]() |
Not trying to run away with this thread, but since we are on the subject. I bought A arms and spindles from a 79 chevy that was 5 lug. I thought about going 5 lug for 5 spoke rims, but now thinking twice about it just for the reason markb01 mentioned. So here is my question, can I just swap out the 5 lug rotors and buy 6 lug rotors? Do I change out wheel bearings and caliper too?
It still will be easier than messing with the rear end.
63 Chevy Long Bed 283 Powerglide currently apart! |
I have 6 lugs all the way around and the only problem that I have run into is trying to find a push through hub cap for the 6 lug rally wheels that I have.
#14 | |
'66 chevy lwb c10 '65 chevy lwb c20 |
#15 |
Ill be the black(mopar)sheep here - Im planning to swap my fronts to the 5lug when I do my drop spindle/disc swap in a few weeks - I dont plan on changing the rear to 5 lug for a looong time (until cash permits) and if/when I do Id probably just do the swap kit that Speedway has. although kinda pricey:
http://www.speedwaymotors.com/1963-7...Kit,46254.html Is it really that big of a deal to run 5lugs up front and 6 in rear? |
#16 | |
Senior Enthusiast
If I were going to take another long trip I'd probably toss in the spare and the jack along with a variety of tools, but for local travel it just adds more rattling clutter in the bed. |
#17 | |
#18 |
i dont rock hubcaps - ive always felt they had something to hide (ahaah dont worry - im at my day job right now)
i dont even carry 1 spare - I meet the best people on the sides of roads FWIW - My choice will likely be the 5x5 Wheel Vintique 62 series Im prettu sure they do a 6 lug version too - ill look for a linkie |
#19 | |
AFAIK, those 62 series wheels don't come in 6 lug. I wanted to go that route too. |
#20 |
#21 |
Senior Enthusiast
#22 |
i know ive screwed the OG topic but those are too sweet (and 6 lug) but are 16" - from wheel vintiques also according to the classic trucks article
#23 |
#24 |
C/10 junkie
Does anyone know if the stock 6 lug wheels that came on my 68 will fit over the 6 lug disc brake conversion?
#25 | |
Senior Enthusiast
http://67-72chevytrucks.com/vboard/s...c+brake+wheels If the back of your wheel has the conical or tapered shape shown on the Rader mag in post 4 of this thread, it probably won’t clear the caliper: http://67-72chevytrucks.com/vboard/s...c+brake+wheels The truth is the only way to know for sure is to try mounting the wheel on an assembled disc brake & caliper. Some drum brake wheels fit while others do not. I’ve mounted both early 1960’s Dragmaster mags and factory Buick wheels designed for drum brakes on my front disc brakes. Both fit fine, although the mags needed a very tiny amount of clearance grinding on the calipers. Whether any particular wheel will clear the caliper depends on the shape of the wheel center, offset, and shape of the wheel rim on the back side. |
