01-10-2012, 09:57 AM | #1 |
hey guys can i see some stepside rear tires?
just wanna see some shortbed stepside with some rear tires for me to figure out what i want!
01-10-2012, 03:31 PM | #2 |
Re: hey guys can i see some stepside rear tires?
What are you interested in? You can look through my photobucket pages. I currently have 17x9.5 wheels(5.5" bs with 7/16" spacer) with 275/55/17 tires. My old setup was 15x8 wheels with 275/60/15 tires.
http://s221.photobucket.com/albums/d...ick68/My%2068/
01-10-2012, 03:35 PM | #3 |
did it rub at all with the 275's on the 15s?
01-10-2012, 08:15 PM | #4 | |
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
01-10-2012, 03:38 PM | #5 |
Not even close. The 17's rubbed on the inside because the backspacing is too deep. That's why I'm running spacers. I should've ordered 5" backspacing to start with
The 15's had 3.75" bs.
01-10-2012, 03:50 PM | #6 |
what about sticking out of the fender well?
01-10-2012, 05:11 PM | #7 |
No they fit inside the fender just right. You will have to be carful running 15x10's though. If the backspacing isn't right, they will poke out. 4.75" backspace would be perfect backspace on a 15x10.
01-10-2012, 07:07 PM | #8 |
What is the distance from fender lip to fender lip on a stepside?
Posted via Mobile Device |
01-11-2012, 10:44 AM | #9 | |
The earlier rear end is 55.5" plate to plate. The later rear end is 57" plate to plate. So, if you have the later rear end you could run .75" more BS than I do. (1.5" total width difference) But it would make the wheel look .75 narrower on each side. (less lip on the outside as the rear housing width would 'eat up' that .75" of wheel lip) Still the same width wheel, it just sits back .75" further. How low is your truck? You going with 15's, 17's, 20's + ? ?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) Last edited by CC69Rat; 01-11-2012 at 11:22 AM. |
01-11-2012, 11:10 AM | #10 |
1969 Custom 30 wrecker
I wanted the old school look of big steam rollers sticking out so here's mine.
The wheels are 15 X 10 with a 3.5 backspace. Tires are 275/60/R15. I recently swapped the tires to 295/50/R15. They are a little smaller in diameter and a bit wider tread.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
01-10-2012, 08:52 PM | #11 |
I've got 17 X 10 rims with 285/55 tires and no rub. I'll take some pics tomorrow.
71 Chevy Stepside 377/350 |
01-11-2012, 10:08 AM | #12 | ||
I've never measured.
