Where to buy factory style rubber floor mat instead of carpet
Where is the best place to get a factory style rubber flooring. Everytime I have searched all I have come up with is the carpet flooring.
I am a Referee of life.
Re: Where to buy factory style rubber floor mat instead of carpet
I can't tell you that they are for sure the best,though I suspect there's only one manufacturer,but "Top Banana: used to carry them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Several truck part suppliers carry them, LMC Trucks, etc. The big discussion around the board recently has been finding a rubber floor mat that doesn't start falling apart after two years. I would like to find a heavy duty mat for my 68.
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
All the usual suspects carry them, LMC, The Truck Shop, Classic Industries, Brothers, etc. mine is from The Truck Shop, about 1 & 1/2 years old and looks great.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Are they the same thickness as the originals?
I went to put one in a while back that was supposed to be fitted but wasn't very well, looked like crap. So I put carpet in instead
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
LMC (Lots More Crap) sells a 1/8" thick poly floormat. I have one in a ford and it seems to hold up good.
BlahBlahBlah
I don't know where board vendor PICKMUP sources his, but I have one in my K20 from him. Fits great and isn't falling apart.
The Older Generation
Be very careful... A lot of the new ones are not molded very well. The pattern has no detail. A couple of the vendors have temporarily quit selling them.... My supplier has one good one he is saving for me but he says the latest ones look pretty bad. LockDoc
1969 Custom 30 wrecker
Got mine from Classic parts and it's dry rotting / cracking after about 2 years. Really disgusted about it since they cost $85 stinkin dollars! And what's worse is I have 2 more not installed yet for my other trucks.
![]() Unless your selling your truck soon, I'd recommend something else.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Too bad on this one. A good quality mat is one of the nicer features of these trucks.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
I just installed one in my 68 low hump, bought it at Brothers, first one i got was for a high hump, they picked it up and shipped out the right one ASAP. It fits ok , tiny bit short on width but not bad overall, dimmer switch cut out is a little bit out of place. Also got under mat felt kit, but it is a universal fit and leaves a lot of floor bare metal ?
![]() Join Date: Aug 2011
Grancuda- we sell the rubber mats for your years. Troubles with installing them have always come from the east coast guys and northern states where the weather is cold. This is simply because once the mat is molded and cut it is wrapped up and packed into a box. this could sit on the shelf for 2 weeks to 2 years just depends on how many they run at that time. This causes a problem when you want to unwrap your mat and through it in the truck. The mat needs to be warmed up and let it come back to its original shape. In nice southern California we put them out on the driveway for 3-4 hours and bam its back to the original shape, back east different story I have had a couple customers have good luck with letting them lay flat in the living room and sometimes using a heat gun to get corners to lay out perfectly. Carpet, rubber floor mats or vinyl floor mats which ever way you go we have the products you would need.
#14 | |
Do you have any photos of them installed and what they look like? Are they the same pattern on them as a stock one?
#15 |
Looking through my photo gallery I do not have a picture of them installed. I can however get a picture of the pattern for you if you would like to verify the pattern.
#16 |
Mine is a LMC unit. Holding up well after 5 years of near daily use.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#17 |
![]() Join Date: May 2011
I just got a low hump floor mat fiom brothers. Looks okay. No real notiocable difference from the original. Does look like the hi beam hole may be off a bit just looking at it, but I should be putting it in in a week or so and can post some finished pics/ reviews
#18 | |
#19 |
pictures of the floor mat patterns.
#20 |
#21 |
Got mine at Classic Parts. It fit really well and seems to be a good quality. Only had it a few months though so not sure of the long term durability. I wish someone sold them in colors.
#22 |
Gotta say I did find the Brothers Floor Mat to fit very well. I did have to trim two spots, but all in all I was happy. The mat is very close to the original thickness and the pattern looks great. I was afraif the High beam hole was in the wrong place just looking at the mat out of the truck, but it turned out to be just fine. I Put this in after leaving it rolled up in the box for a month in a cold NY winter garage. I laod it out in my Living room for a few hours first. And it went in very well! I would recomend at this point for sure.
#23 |
Cool and looks great!
#24 |
Got mine from Brother's fit's like a glove and has held up great so far and it's been 2 years. no cutting what so ever, i also put the factory style sound proof set in with heat resistant padding and the factory jute padding. turned out really nice, you can't go wrong with there's.
#25 | |
padding as well |
