Old 01-11-2012, 06:36 PM   #1
aric68
Newbie in over his head
In my 72 k20 I'm attempting to replace u/ball joints, and repack the bearings, trying to save a buck. Literally had to watch a video to see what and where these were. I got the spicer hub assembly off which wanted to come off as 1. Was able to remove the inner bearing lock nut with my fingers, but can't get the thrust washer off. Any advice and pictures would be appreciated.
aric68 is offline   Reply With Quote
Old 01-11-2012, 07:49 PM   #2
72LSK10
72LSK10's Avatar
Re: Newbie in over his head
If you've already removed the nut, pull the washer straight out. I usually use a set of picks, the 90 deg and the offset ones seem to work the best for me. the inner and outer bearings will come out along with the hub assembly once you remove the second nut (behind the washer). I hope this helps.
72LSK10 is offline   Reply With Quote
Old 01-12-2012, 10:42 AM   #3
Burt4x4
Burt4x4's Avatar
There should be a notch the washer slides in. Onetime my washer spun a bit and the washer was wedged in one directrion. A few taps the opposite way and I was able to pull it out with two picks/hooks.
Try tapping on it...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-12-2012, 01:40 PM   #4
aric68
thanks for the help I was looking for a tab, found the 2 picks worked well. Struggled a bit but finally got the axel out. Will attempt the knuckle removal, and joints removal today. Everyone I've talked to is scaring me a bit with how critical putting it back together is. searched online but cant find good details on my front end.
Old 01-12-2012, 02:17 PM   #5
OrrieG
OrrieG's Avatar
There was a long thread last year about R&R and adjusting the bearings. Not rocket science. I made my pic tool out or a coathanger and carry it in my offroad tool bag.
Old 01-12-2012, 03:43 PM   #6
aric68
Does this look dismantled correctly? Name:  IMG_0914.jpg
Old 01-12-2012, 11:23 PM   #7
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
looks good to me.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-13-2012, 12:17 AM   #8
aric68
all the info i had gathered told me there was a spring, lock washer, and snap ring to get the hub assembly off, but I didn't find those.
Old 01-13-2012, 01:16 AM   #9
Chevy1TonFun
Grease Monkey
I wasn't paying attention to the hub. You are correct you are missing some parts.
Old 01-13-2012, 01:33 AM   #10
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
You should have had a snap ring on your axle stub....the spring should be between the axle gear and the retainer you have in pic #1 you should have an actuator cam between the two with a pin thru it holding it to the dial.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-13-2012, 01:59 AM   #11
aric68
am i ok to reassemble as is?
Old 01-13-2012, 02:02 AM   #12
aric68
does anyone have pics of what its supposed to look like?
Old 01-13-2012, 03:25 AM   #13
Ridgeback
aric68
If you post your email address I will send you a pdf file containing the Dana Spicer Manual
Ridgeback is offline   Reply With Quote
Old 01-13-2012, 10:12 AM   #14
aric68
aric76@gmail.com
Old 01-13-2012, 04:49 PM   #15
Ridgeback
aric68
Sent you two emails. Let me know if you have any trouble downloading the manuals.
Old 01-16-2012, 11:16 AM   #16
Curt's_72
Curt's_72's Avatar
Good information in this thread. I just removed the same hubs from my truck to detail them. What are you using for a gasket? I notice yours are in pieces like mine were when i removed them. They are very thin, also.
Curt's_72 is offline   Reply With Quote
Old 01-13-2012, 06:07 PM   #17
SeventyOne
Re: where can i find info for doing my U and ball joints on my k20s
It looks like you are missing hub parts. Did you just take those off the truck? If so whoever was in there before didn't know what was going on.
SeventyOne is offline   Reply With Quote
Old 01-13-2012, 07:06 PM   #18
aric68
I did just take those off the truck, and I stopped by and showed a couple mechanics and they both thought it looked fine and not missing anything.
Old 01-15-2012, 04:09 PM   #19
aric68
worked great before
Old 01-14-2012, 08:52 PM   #20
cdowns
cdowns's Avatar
gm factory service manuals has loads od important info
