Rally Wheel restoration
I was lucky to get the full set of rally wheels with the caps and trim rings from the original owner of my truck, I am going to remove the old tires and prep them for paint, any suggestions on where to get the most correct, durable product?
thanks in advance, Chris
1985 Custom Deluxe long bed 305 3 on tree 2015 Silverado "Great White"1987 K20 dump and plow 1968 K20 327 long bed 4spd big blue 68K20 SuburPan 4spd 79C30 L96 6L90e 86 K10 plow |
Re: Rally Wheel restoration
![]() Join Date: May 2009
I did a set of Vette raly`s yrs ago. I had the wheels blasted, primed them with gray primer, sprayed them with Krylon. At the time, I didn`t clear them, but would now. I guess it depends on your budget.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
GM Addicted
powder coat them, not as expensive as you think and it will look great for a long time
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
![]() Join Date: Oct 2011
I had a 85 k5 with 6in lift back in the day (white black top) i bought it in 87 and had it 11 yrs....anyways i sanded them and painted three coats with krylon...sanding between coats ..they were very smooth and shiny....i painted them white to match the blazer...it was a nice change from silver...made the caps and rings stand out better....got lots of compliments back then...that krylon held up great all those yrs.....should never have sold it
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
yeller
2nd on the powdercoating...durable, looks great, and not all that expensive considering they blast the wheels to bare steel too.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Ditto on the Powdercoat. Did mine on my 85....
Where did you get the trim rings? I just bought a set of rallys and caps over the weekend. But I need rings.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
78K & 79C Jimmys
havn't tried the "right" colour ,have just sprayed them with rust paint in cans
have three sets of the rings,hate them cause of the "teeth rust" ..... don't use em just the centers but i am getting my set of wagons done powder white for the jimmy next summer a friend showed me a place that will do them bout 50 each... i have a pot blaster,what a mess to clean up tho.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#10 | |
http://www.jaeeagle.com/products.php?search_text=4523 Powder coat was done by North County Powder Coating in San Marcos, CA. Ran about $50/wheel |
I restored a set a few years ago. By the time I had sanded and primed, sanded and primed , sanded and primed , sanded and primed then painted. I wish I would have powder coated them. Didn't have anyone close to powder coat them at the time.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
is there a certain color code you guys are using when the wheels are powder coated or repainted to achieve the factory look? thanks
When I went, they had a color chart / samples and I just compared to what looked as close to factory as possible....
I removed the old tires and cleaned up the rims a bit to see what I had to work with.....
![]() ![]() Most of the damage is from the trim rings. Change you use the trim rings after powder coating without damaging the finish? I had planned on just painting them and leaving the trim rings off since these wheels were just going to be for winter/snow tires.
#15 |
Yeah I am going to get mine powder coated too. They said they would sand blast them and high gloss silver powder coat them for $50 a wheel. Friend of mine said to heck others in my area casue some will do it for even less he says. Not very expensive to do and they will last a very long time.
#16 |
nice....That will help...my rings dont look bad but they dont look great!!
#17 |
If you don't want the expense of powder coating. Duplicolor wheel paint, the color is "Steel Wheels" about 6 bucks at your local parts store and a near perfect match. Done a bunch of them with it. I use gray primer first and one can of the paint will do four wheels nicely. Not powder coating but cheap and looks good.
#18 |
I did these with a Eastwood home powder coating gun and a standard kitchen oven. Charcoal rally wheel powder.
![]() This one has a smaller trim ring. ![]() |
#19 |
How does the Eastwood powder coating gun work?
RIZ |
#20 |
I have the Eastwood base gun and it works well. I also have the Caswell adjustable voltage gun and like it a little better. To use either gun you will need a small compressor or the ability to turn down the pressure on a large compressor. I run both guns around 10 PSI. Use the least amount of air PSI to get the powder to lay down correctly. Too much air and you end up wasting powder, not enough and it does not give you a consistent coat of powder. The part you are coating has to be able to conduct electricity and be able to withstand the heat required to cure the powder. The gun has a positive charge and you hook a ground wire from the gun to the part. This causes the part to have a negative charge and thus attracts the powder. Once the part is coated then you set the oven to the recommend temperature of the powder. There is a temp setting to get the powder to flow out. Once the powder looks like liquid then you reduce the heat to the recommended cure temp and let it bake for the recommended cure time. Once the part has cool down you can put it in service. To use the gun you just load the gun with the powder. I sift my powder before loading it into the gun to remove any chunks of powder. Ground the part and plugin the power cord, set your air pressure and spray away. I do recommend a good respirator as you don't want to inhale this stuff. I like the adjustable voltage gun better because I can turn down the voltage on small parts and up for larger ones. My opinion is that gives you a better coat and helps reduce the wasting of powder. Cleanup is easy you just dump the unused powder from the gun back into the container and then turn up your air PSI a little and blow the extra powder out of the gun. Disassemble the gun and wipe it clean with a dry cloth. Sweep the area with and throw the excess in the trash. Some people build a cabinet with a small exhaust fan or shop vac to catch the extra powder. Kinda like a sand blasting cabinet with a vac just with one open side for spraying. I like the process better than painting. It gives you a stronger finish and resists most common chemicals. The only restriction I have is the size of the curing oven which in my case is an old standard kitchen oven. The larger oven you have the larger part you can coat. Don't use wifey's/moms kitchen oven because it's not recommended to cook food in an oven that has been used for curing powder. Practice on some old parts until you get comfortable with the process. I hope this answers your question. Good luck. Most of this bike was powder coated with the exception of the gas tank, frame, engine and plastic parts. All of the polished parts were coated with clear powder and others were coated with almost chrome powder. All the black bolts you see are powder. The wheels were done with satin black and I used a special tape to cover the polished part of the wheels. Once the black flowed out I took the wheels out of the oven and recoated them with clear powder then cured them. ![]() |
#21 |
cool, thanks for the info and nice work.
#22 |
Powder coating not nearby or in the budget, now I've tried two different colors of the Krylon but both are too "chrome" looking. Anybody have a source for a more "argent" color?
#23 | |
Sidebar: I used it on my grille and headlight bezels, too, since it was the right color:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#24 |
I wound up getting the Argent rally wheel paint from Eastwoods. After reading Keith's post above I got a couple of extra cans and hopefully will repaint my grill and headlight frames also (not that I was looking to add anything to my list of stuff to do.)
![]() here's a crappy phone pic after first coat. I will get some clear for the finished product. ![]() thanks everyone for the input.
#25 |
Looks good I hope to do this to my rims someday.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
