01-12-2012, 10:50 PM | #1 |
i need help please
im using driver side and passenger side aluminum drive brackets off of a 1990-1994 Chevy 350 V8 or 4.3L V6 truck, with casting numbers 10118701 (driver's side) and 10118751 (passenger side) on my 70 chevy truck and im also wanting to use hydroboost .
the probelm is i dont know what power steering pump to use. please help any info would be great. |
01-12-2012, 11:16 PM | #2 |
Re: i need help please
you can use the pump off of the chevy truck or the s10. You will have to put a T in line to make a return. I have done it before but I don't remember just how I did it, but the pump I used had only 1 pressure and 1 return. You could get a pump from the same model year range as the braket you have and order a pump for a 3/4 [you will need to say with option c6p 8 hole 3/4t]or 1 ton with the 5.7L engine. Also the Astro van had a hydroboost from that era as well so check that out. It seems like I may have run a preesure line from the pump to the box the a line from the box to the booster then a return line to the cooler then from the cooler to the return on the pump. That may not be how it was and if that won't work someone will surely step in and tell me I am wrong. I do know that I have run a regular pump on a hydrobooster.
01-13-2012, 05:34 PM | #3 |
thanks anyone else.
01-14-2012, 02:13 PM | #4 |
i know someone has done this b4.
