Desert Dweller
New window regulators
I just stripped out my right window crank and the window regulator is also stripped from what looks like a set screw. Anyone know of a good replacement window regulator and handle? I looked at some at our last swap meet, but they looked so cheap and it would be nice to find something that will last awhile...
![]() Thanks! Posted via Mobile Device |
![]() Join Date: Aug 2004
Re: New window regulators
I got them from classic parts a few years ago
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#3 | |
Desert Dweller
Senior Enthusiast
I found both NOS window and door latch regulators on Ebay a few years ago. They still turn up every now and then. Don't know how well the new replacement parts compare in quality.
![]() Join Date: Nov 2010
I have an extra drivers door laying around that has all the original window parts that are all free and move if interested.
#6 | |
Desert Dweller
Thanks ![]() . Posted via Mobile Device |
They worked real well for me
Resistance is Futile
Hey Tony; I put one in the '66 on the drivers side and it was a new set-up. It's tight and works well. The only issue I have is that my original window crank doesnt fully engage the splines. I've had it fall off a couple times. I have a new crank but havent tried it to see if it fully engages the shaft better than the old one.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed Last edited by rbar; 01-15-2012 at 01:39 AM. Reason: .. |
I bought one from classic and it fell apart. They sent me a new one and it has worked so far, but I wasn't impressed by it, but it's better than nothing.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
tHE replacement stuff is cheap. I replaced mine on th e64 and never was able to keep them tight on the spline. Very poor quailty. NOS if you can find them.IMO I have orignal on my 66 and they never ever fall off.\
Good luck
Why can't I find it until the last place looked? 65 Longbed 283 three on the tree. 66 Longbed 292 three on the tree.Pennys A/C Trucks made in USA Buy a much as you can, Made in the USA |
Guys if you buy the replacement units, drill the center of the splined shaft, tap it with threads, drill a hole in the handle center, counter sink it slightly and use a bevel head screw, all mopars were this way, had a friend do the same on his truck somes years back and has never gotten loose yet. Also line the splined shaft with a small pisece of aluminum foil to take out the slop of the replacement handles.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#13 | |
Desert Dweller
Thanks guys.
I think I will try to locate a good used oem unit if I can... Since it's the passenger side, I might have a better chance at finding a decent one. I found a NOS on eBay, but I can't afford $94 right now. ![]() ![]() Posted via Mobile Device |
#15 |
Rollin' Old Skool
i believe member Alan (Alan's Classic) installed an aftermarket regulator on his, but i'm not sure where he got it....i had to get one for my driver's door, but i went with a good used one from Tony @ http://4-5-6chevytrucks.com/index.html
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#16 |
Wow i completely didnt notice you needed the passenger side haha sorry i do have window parts for a passenger as well
