Old 01-15-2012, 11:58 AM   #1
westgl
westgl's Avatar
Lowered truck & New Wheels size question
67' Chevy C10 LWB
I will be using,
4/6 Drop Kits (2.5" Drop Spindles, 1.5" Drop Front Coil Springs, 6" Rear Drop Coil Springs, 4 KYB Shock Absorbers, Super Track Bar Kit, Shock Mount Relocator Kit) (Drop Spindles require Disc Brakes)
Changing to disc's up front
With the 2.5" dropped spindles & 1.5" drop front coils springs
Can i use 17x8" Summit Legend wheels 5x5 with a 4.50" back space for the front (5 lug Disc brakes in front)
And 17x9" 5x5 with 5.00" back space in the Rear (i will change the rear axles to 5 lug)
I would like these wheels to fill the wheel wells, and do not want a lot of space between the inner fender and the tire/rim.
Any recommendations?
westgl
1967 Chevy C10 Lwb I6-250ci 3spd manual trans
Future Projects, Power Brakes, Front Discs, Power Steering, Paint Frame, New 350ci engine Bored .040 357ci Magnum, Vortec Heads, Comp XE262 Cam, Performer EPS Intake, 650CFM Carb, Rebuilt Trans 700r4, 2000-rpm stall, Completely Rebuild & Upgrade Front & Rear Suspension & Steering Components, Suspension Drop 3.5" & 5" Drop, 1.250 Sway bar,
westgl is offline   Reply With Quote
Old 01-15-2012, 01:41 PM   #2
big mike71
big mike71's Avatar
Re: Lowered truck & New Wheels size question
I have the same wheels, with the same back space on my truck and I will need a 1/2 spacer on the rear when I lower it.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 01-15-2012, 02:14 PM   #3
westgl
westgl's Avatar
You dont have any problem with the front hitting/rubbing.
But you have not lowered yours yet correct?
I was thinking of maybe going with the 2/4 drop and go a 17x10 in the rear
Old 01-15-2012, 03:15 PM   #4
westgl
westgl's Avatar
Thanks for the info big mike71,
What tires are you running on those rims?
westgl
Old 01-15-2012, 03:18 PM   #5
westgl
westgl's Avatar
The reason I asked about the rubbing I have read on here that people rub with the lowered spindles,
That must be with a 15" rim running more back spacing maybe?
I am a new to getting the right parts the first time.
thanks
Westgl
Old 01-15-2012, 03:14 PM   #6
big mike71
big mike71's Avatar
I'll have plenty of room in the front.
Old 01-15-2012, 03:56 PM   #7
68Stepbed
68Stepbed's Avatar
The front wheels will be fine. However, if you're still using a 63-70 rearend, they are more narrow than the 71-72 rearends, so the 5" bs on the rear wheels will be too shallow. My suggestion is to get 4.5" bs on the rear wheels(if available) or find a 71-72 5-lug rearend. The 5" bs will work fine with the later rear.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-15-2012, 05:30 PM   #8
big mike71
big mike71's Avatar
I have 275-50 on the rear, 255-50 front. you could get 1 1/2" spacer for the back.
Old 01-15-2012, 07:23 PM   #9
westgl
westgl's Avatar
Well I just checked the wheel sizes
They have a couple of sizes,
17x9" in a 5x5 - 5" BS OR
17x8" in a 5x5 4.5" BS
Anyone know how much narrower the 67' rear end is?
Old 01-15-2012, 08:15 PM   #10
westgl
westgl's Avatar
I like those rims maybe i will hunt down a rear end.
Too bad the rear end that is in in there is in good shape and low miles.
thanks for all you help
Old 01-15-2012, 08:24 PM   #11
CC69Rat
CC69Rat's Avatar
67-Early 70 year model is 55.5" plate to plate.
70 (Late) + is 57" plate to plate.
So, Matt is absolutely right. If you have the early rear end, you'll be .75" (.75 x2 sides 1.5" total) different than say someone with a 70+ truck and 5" BS wheel. Ex. IF you were to get 5" BS, the wheel would sit further under the truck as it would on a 70+ year model rear end (since the width of the rear end housing is shorter more narrow) If you got the 4.5" BS on and early rear housing it would sit almost the same as a late rear with 5" BS. With the same rear wheel width. The difference is the outside would look wider .. The wheel would still be 9" wide regardless in both scenarios. You're just offsetting the wheel to compensate the overall width of the rear fenders so the tires 'fill the wheel well properly' .. Make sense?
Also, I have a Percy's Wheelrite I am willing to lend out of you guys need it. It will measure the wheel backspacing perfectly. Just help me out on shipping and I'll loan it to anyone who needs it.
Later ..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-15-2012, 10:57 PM   #12
70chevymanshort
I'm looking at some 18x9.5, 5x5 bolt pattern wheels with a -4 offset. Will they work on my 1970 chevy truck?
Last edited by 70chevymanshort; 01-15-2012 at 11:01 PM. Reason: need my own thread
70chevymanshort is offline   Reply With Quote
Old 01-15-2012, 11:07 PM   #13
westgl
westgl's Avatar
Thanks CC69Rat,
That is some good Info, that gives me a better understanding of what is needed or can be done.
I may try to use longer Wheel Lugs and a 1/2" thick alum. spacer behind each wheel and see how that works.
Old 01-15-2012, 11:10 PM   #14
westgl
westgl's Avatar
Hey that's ok 70chevymanshort,
But you'll have to put $20.00 into the thread jacking jar.
that's my retirement money.
Old 01-16-2012, 06:45 PM   #15
westgl
westgl's Avatar
I do Not want to go with a spacer.
I found some wheels that may work.
Truck will be Lowered to 3.5x5"
Stan at ECE suggested that i use the following Size rims and Back space for my 67'
I am going to use Centerline wheels,
Front 17x8" 5x5 4.50" Back Space
Rear 17x9.5" 5x5 4.50" Back Space
Old 01-15-2012, 11:04 PM   #16
70chevymanshort
Westgl, sorry for asking a question on your thread, but i have the same drop and i was wondering if those rims were gonna work.
Old 01-16-2012, 07:38 PM   #17
big mike71
big mike71's Avatar
With those wheels your backspace 1/2" less, but your rearend is a 1/2" narrower, So there may still be an issue.
Old 01-16-2012, 10:23 PM   #18
westgl
westgl's Avatar
Thanks for helping me out
If i am 3" over all shorter on the 67' rear end.
Well I gain 1/2" on the back space and 1/2" on the wheel width going to a 9-1/2" wide wheel.
I guess i could try to find a 10" wide rear wheel with a 4.5" Back Space
That's 1" on each wheel, so that should take up 2".
I will be 1/2" short on each side.
I think that will be acceptable, considering that i will not have to change my rear end out.
If not then a 1/2" spacer.
