Pics of emergency brake cables turbo 400?
Was the setup for a turbo 400 different than for turbo 350. Got cables from 350 and they appear to be too short for 400. Where does the cable run in relation to the mount ? Thanks
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
Re: Pics of emergency brake cables turbo 400?
1950 Chevy 1500 1961 C-10 1969 C-10 1971 Chevelle 2008 Dodge HD3500 Tow Rig |
Here is a mocked up tailshaft from a TH 400. As you can see in the picture the cross member for the TH 400 is different from the one for a TH 350. The intermediate cable is shorter since the cross member for the TH 400 sits rearward more and the cable is routed through the eyes on the cross member.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
![]() Join Date: May 2010
My original 69 CST/20 has only one loop centered on the crossmember under the driveshaft for the cable. Otherwise it's similar to the one posted above.
Here you go. 68 C20 with SBC, TH400, and coil rear, if that matters.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
![]() Join Date: Jun 2005
Is the crossmember actually different or does it just bolt into different holes on the frame?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
The loops are riveted on the picture of the 72 cross member that I posted.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 01-17-2012 at 08:34 PM. Reason: Added wording |
