Hello ... I am wondering when GM switched to Disc brakes up front did they leave the 15" rim as stock. Or did they have to switch to 16" rim to fit the discs...
It is probabaly the spindles not the disc brake that is the issue. I am going to put drop spindels and disc brakes on the front. I hear I won't be able to use my 15" rims once I do this.... I have 18's that will work but really like the 15" rim with MT's and dog dish look too. If I can't use my 15" rims once I convert I will have to drink a case and think about this.... Thanks for any info in advance..
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Re: Disc brakes with 15" rims ?
Some of the Chevy Truck Gurus will correct me if I am wrong. Our trucks (67-72) switched to factory front disc brakes in 1971 and they used 15" 5 lug wheels. My 89 Chevy has discs up front and 15 inch wheels also.
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
Cool...so it must be the 2" drop spindle that screws up the 15" rim fitting on there with disc brakes??
I have not done the swap, but saved this picture from a post a while ago - it may help you determine ...
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
Scrapper 1
funny thing about back in that time 17 inch rims are un heard of on are chevy trucks from the C10--c20's 15 was standard all the way up from 1957--1995.
1967--72 only had 4 wheel choices 15 inch for 1/2 ton and 16 and 16 split rim or 16.5 and drop spindles did not come around for are trucks until 1984-87 then the truck faze really kicked off |
I have the CPP drop spindle kit w/ 12" rotors, and 15's I bought fit fine. If you go to a 13" or larger rotor, then 17's are needed to clear the calipers.
the 71 and 72 trucks i had with drop spindles and stock 71disc brakes had no problems clearing 71and up style wheels
earlier drum style wheels as pictured above dont clear disc brakes// was a pretty commn problem for all manuractures back in the day even had problems with some of the earlier mag wheels too
#8 | |
Senior Moment
![]() Join Date: Mar 2002
Even with having the "wont fit rim" with a small 1/8 " wheel spacer mine work fine
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#10 | |
wrong thread, oops.
![]() Join Date: Feb 2004
I cant imagine a 9x 15 working on front with a drop spindle . As stated 4" bs is near max with drop spindles because the lip hits the lower control arm when turning. And if you have a 9 with 4" bs. Your probably gonna be sticking out past the lip of the fender at least while turning so if your. Planning on running springs to you will likely have contact on the tires. I had to raise my truck 1/2 in to clear my tires and you still have to be careful and I completely removed the inner fenders and lips. Mine are 15x8
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
![]() ![]() Join Date: Jan 2011
I have 2.5" McGaughy's dropped spindles and 1.25" HD rotors (73+ swap) with 15x6.5" Van rallys on my truck now. No problems at all.
Ya the CPP site (which has copyright or would paste it) says "May not fit with factory wheels" hummmmm I hate guessing with 20% off returns....plus shipping.
6370SWBK6OE 1963-70 O.E.M., 6-lug, drop, kit Photo/Info $599.00 This is the kit I am looking at... |
#15 |
If you're talking 6-lug rims, look at the 4x4s. '71-87+ (not sure where the plus sign ends) should fit.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#16 |
All ready have the rims...I just hope I can use them after spending the $600 bucks...
#17 |
Contact Aaron at CPP - maybe he can tell you if your wheels are OK to use.
#18 |
I sent an email, may have to call if no reply soon....
#19 |
Moderator
![]() Join Date: May 2007
if you are running 5 lug wheels, 15 in. will clear disc brakes with dropped spindles. i have 2.5 dropped spindles and 1 full coil cut out of my oem springs for a total of 5 inches of drop up front. 5 lug rallies and oem steelies (both 15") clear with no issues.
if you are running 6 lug 15" wheels you need to get 71 and up wheels as mentioned above that were designed for use with discs. Posted via Mobile Device
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#20 |
Project 7dos
I've got 5.5 up front using 2.5 spindles... No issues on a 15x7 rim.
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
#21 |
I am running stock 6 lug drum brakes with bags.... Need the drop spindle for the truck to sit right and even tire wear.
#22 | |
![]() Join Date: Oct 2009
If you want to run a spacer that may help you clear - but it may not... For the folks that mentioned a spacer worked - you'd need to verify that they spaced a non-disk brake tapered inner 67-68 15" wheel to know if that's the right spacer for you. What you REALLY need if you want stock steelies and disk brakes and 6 lugs is a 71-87 K10 wheel. It's a true 15" 6 lug disk brake factory steelie (rally wheels fit disks, but you said you want steelies, so steelies are not rally wheels, so I'm not talkin about rallies - but they are an option - some folks were posting rallies, sounds like you only want steelies, correct?). Keep in mind, even if you have disk in the front only - you really need 3 disk brake wheels minimum if you want to have a spare that will work on all 4 wheels. I'm looking for a set also, and they can be hard to find, but I'm not in a rush, waiting til someone offers 5 then will pounce on ebay or a seller here... But anyway, these are what your really need based one what you said you're wanting to do with your truck |
#23 |
Ahhhh the secret is out now! Wheel spacer brings it out far enough to clear the caliper?
I was day dreaming about shaving some metal off the caliper but a wheel spacer is brilliant. |
#24 |
I'm running 15'' rims with the CPP disc's all 4 corners...yes their 4x4 rallies and it's got 2.5 dropped spindels. sorry for the old pic.
Brian. '70 GMCHEVY '51 chevy "tin woodie wagon" IF YOUR CONFUSED I'LL USE smaller WORDS! |
#25 |
Old member
My 71 had factory disc up front and I ran 8" x 15" ralley wheels for a long time with no problems.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
