Old 01-17-2012, 11:13 PM   #1
Spruckalufagus
Axle hitting crossmember
I have an 82 gmc k1500 with a 4 inch suspension lift. when put into 4 wheel drive the front drive shaft hits and clunks off the tranny cross member. Why is this? Do i need a transfer case lowering kit? by the look of it the transfer case should be raised up to have clearance over this crossmember
Spruckalufagus is offline   Reply With Quote
Old 01-17-2012, 11:54 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Axle hitting crossmember
My brother's truck was doing the same thing. The cardan joint was hitting the crossmember. I got him a spacer that went between the driveshaft and the flange on the tcase. Problem solved!
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-18-2012, 12:05 AM   #3
rcbildr
rcbildr's Avatar
Is the crossmember on correctly. There is a spot on the x-member that is tapered to allow clearance for the joint...I found that out the hard way once. What condition are the rubber mounts on the x-member...maybe they have deteriorated enough to cause problems.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 01-19-2012, 10:23 PM   #4
Spruckalufagus
yeah the crossmember is on correct, but where can i get these spacers you were talking about?
Old 01-20-2012, 01:12 AM   #5
Chevy1TonFun
Grease Monkey
Heres the link to what you are looking for. I just got one at the local 4 wheel shop.
http://www.superlift.com/accessories...ts-spacers.asp
