needs more $$$
Exhaust with blazer tank and bagged...
Sorry for another exhaust routing question, but I'm getting closer to be able to take my ride to the exhaust shop. I've seen exhausts run over the axle on bagged rides (c-notch only), but I don't recall seeing it done with a blazer tank as well.
I'm sure my exhaust shop will be able to tell me for sure, but I was wondering if anyone has theirs ran all the way back with a similar set up...or am I stuck with dumping it before the rear axle? By the way, I have shorty headers and the exhaust will be tucked in the frame and through holes in the ta crossmember if that matters. Thanks!
1970 2wd Blazer |
needs more $$$
Re: Exhaust with blazer tank and bagged...
TTT...
I'll only do this once...I guess it's not possible.
1970 2wd Blazer |
Junior Member
I've seen another thread on this with pix so I'm planning on it being possible to go over the axle and then immediately outside the frame rails on my project. I'm sure others will chime in with actual installations.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
dazed and confused
I will try to get a picture tomorrow. Mine is ran over the axel and out the sides. It has 4-6 drop and a blazer tank. It is pretty tight on mine. But I think it can be done
members met: redbaron69, billsbowtie,nc67 |
i also need to know...
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
needs more $$$
I guess I didn't search very well because I did find this post with a few pics:
http://67-72chevytrucks.com/vboard/s...ad.php?t=72367 They aren't bagged, but you can get an idea of what's needed to go over. I don't think I'm going to be able to go this route after all. I think where I routed all my air lines is going to cut it too close for comfort...looks like pre-axle dump may be my only choice...not looking forward to the drone with the top on...
1970 2wd Blazer |
I just went thru this and for the time being I put turn downs before the rear axle. I hate the sound and looks of it but I wanted to drive my truck after putting air ride and four wheel disc.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
I have decided that I'm am going under the rear end to get my exhaust out the back
Posted via Mobile Device |
