![]() Join Date: Apr 2010
Power steering pump fitting.
I know this has been talked about but I can not find a thread that tells me where I can order a fitting to put into a newer pump to use old style flare lines. Anyone know where I could order one? I don't have an old pump to pull it from and don't want to buy a pump from a junk yard just for the fitting. Thanks.
Re: Power steering pump fitting.
Well what worked for me was this...
I did a 5.3 swap a few years ago using the 2002 power steering pump. I was able to remove the fitting from my original 68 pump and it screwed right in the new pump same threads and both use an internal o-ring. it has worked for me like this for years. Oh, nevermind I just read your post again and see you dont have an old pump. I dont know if a parts store would have one? You might give them a call like I said my stock one seemed to work.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
I am a Referee of life.
I did the same.You can probably just get the fitting at the JY.Should be the same on most of this era pumps from GM.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
What year pump are you using? I have a '69 C20 and put a '91 power steering pump. I just took the fitting out of the new pump and the '69 high pressure line screwed right in.
I don't have an old pump to take the fitting out of!
the new pump I bought from pepboys had a metric female fitting already in the pump. The new pump is a standard size, but they put a metric fitting in that because the power steering line from a '91 is metric. I just removed it and my stock '69 power steering hose fitting screwed right in the pump.
![]() Join Date: Oct 2006
These guys don't show a price, but there are fittings out there that work if you don't have an old pump to swap one out of.
http://www.purechoicemotorsports.com...rod/prd336.htm |
