![]() Join Date: Mar 2011
C30 DRW, what size tires????
Ok you 1 ton guys, what size tires do you run on the duals. I want to get as tall a tire as I can without them rubbing. I have 1 piece wheels off of a 80 chevy they are prob 7 or 8 inches wide.. the tire shops around here keep telling me different things and I don't really know sizes that well. Coop
1971 K20, Coop's beast (project) 1972 C30 wrecker, "Big Ernest" (SOLD) 1975 K5 Blazer (wife's toy) she got it in the divorce 2014 Street Glide Special 1983 K20 Big Block, auto (work horse) |
Re: C30 DRW, what size tires????
235-85-16 is the biggest tire you will be able to run without them rubbing each other without a spacer. These will actually kiss each other if you overload real heavy, but for normal use they will be fine.
![]() Join Date: Sep 2004
Yep that's thats been standard size for a daully for a long time. Tall and narrow.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
I'll have to double check, but I think mine on the wrecker are 235/75/16
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
thanks, can someone explain these dang metric tire sizes to me? the first number is millimeters wide ? and the second is height, but I know its not millimeters. and the third is wheel size in inches, so what is the unit of measure for the height?? Coop<
235/85-16s are as close (if not the same) metric radial size/profile as the 7.50-16s bias plies that came on these trucks. 85 series is the taller/narrower profile. The higher the first number the bigger the tire. The second number determines the height to width ratio. The lower the number the shorter and wider.
thanks guys that helps a lot. this is why I love this board so much, there is always someone with the knowledge to help a dummy like me. Coop
