01-20-2012, 08:43 PM | #1 |
Vin Number help
Need a little help.
Looking at purchasing a 1966 C10 Stepside The metal tag on the door reads: chev. od bid c144 c66157 vin# 6Z17xxxx Does any of this makes sense? I know the c144 means 1/2 ton step-side The rest? Thank you for your time |
01-21-2012, 10:23 AM | #2 |
Senior Car Nut
Re: Vin Number help
if I understand correctly, the numbers 6Z17xxxx mean
6 for 1966 Z for assembled in Fremont (CA I believe) 17xxxx means the 7x,xxx unit built that year at that plant on my truck the VIN looks like (using your #'s): c1446Z17xxxx the tag is on the cab door frame above the door, not the door
Larry |
01-21-2012, 11:16 AM | #3 |
Re: Vin Number help
yes that is a 1/2 ton the 6 is 1966 the z is fremont assembly plant the rest of the number is the production number they all start with 1 then the rest is the number made at that plant . example 177193 would be the 77193 truck built at that plant that year . if you have the full number i can give you what month your truck was built in mike
01-21-2012, 11:21 AM | #4 |
Re: Vin Number help
Great information...Thank you the full number is 174940
Thank you |
01-21-2012, 11:25 AM | #5 |
Re: Vin Number help
your truck was built in june 1966
01-21-2012, 11:47 AM | #6 |
Re: Vin Number help
Thank you for the information again
01-21-2012, 03:34 PM | #7 |
"Where were you in '62?"
Re: Vin Number help
Vin Number query
http://67-72chevytrucks.com/vboard/s...d.php?t=402078
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
01-21-2012, 08:14 PM | #8 |
Re: Vin Number help
I just looked at a 66 truck with vin C144 C-6-177 with a 6Z156681 and it is a stepside but I didn't think t you could decode the vin to the bed. IE is there really a way to tell if it was fleetside or stepside.
01-21-2012, 11:00 PM | #9 |
Re: Vin Number help
yes you can c1404 is stepside short c1504 longbox both 2 wheel drive c1434 short fleetside c1534 longbox fleetside these are all 1/2 ton trucks mike
01-21-2012, 11:30 PM | #10 |
Re: Vin Number help
WHat does the one above decode as, also my longbed fleetside is a C1545Z and it is a 65 but I don't see how that decodes either, other than it is a 127" wheel base but what is the 45, in my book it doesn't jive.
01-22-2012, 10:11 AM | #11 | |
Senior Car Nut
Re: Vin Number help
4=stepside 5=1965 Z=Fremont I have the same problem with my '66 Fleetside, which codes as a stepside EDIT: I just checked my '65 Fleetside, which also codes as a stepside. so either I'm reading my assembly manual wrong or the manual is wrong. or, both had the beds swapped at some point. I would guess that a factory mismatch would not have been unheard of 2nd EDIT: post #4 on this link makes more sense (from the links 1Bad62Pro/Steet supplied)
Larry Last edited by fleetsidelarry; 01-22-2012 at 10:41 AM. |
01-22-2012, 10:26 AM | #12 |
Re: Vin Number help
did you look at the buildsheet if it is still there behind the seat ? that might give some clues? it might be a special order truck . i will look at some other stuff i have mike
01-22-2012, 10:44 AM | #13 | |
Senior Car Nut
Re: Vin Number help
http://67-72chevytrucks.com/vboard/s...19&postcount=4
Larry Last edited by fleetsidelarry; 01-22-2012 at 10:50 AM. |
01-22-2012, 11:04 AM | #14 |
Re: Vin Number help
I have the build sheet for my longbed and the model number does decode to a fleetside on the build sheet but not the vin I guess.
01-22-2012, 11:37 AM | #15 |
Re: Vin Number help
Here is a pic of the vin tag on this truck I looked at, I have never seen one with the extra stamping, any ideals.
01-22-2012, 12:13 PM | #16 |
Re: Vin Number help
the truck was built feb of 66 is the c date code for march 66 would be the delv. date and the 177 the bid contract? 144 is strange . is it a short wheel base?
01-22-2012, 01:03 PM | #17 |
Re: Vin Number help
Is it a SWB setpside, paint, anyones guess.
01-22-2012, 07:32 PM | #18 |
Re: Vin Number help
look at the kick panel on the drivers side the tag if it is still there? will have the paint code and other options mike
01-22-2012, 12:06 PM | #19 |
Re: Vin Number help
it looks like the tag was taken off then stamped the factory rivets are gone . what is the original color is it a navy /airforce colors
01-22-2012, 09:50 PM | #20 |
Re: Vin Number help
On the one I am looking at, it has the tag on the kick panel...is there a website that tells me what the original color was?
01-22-2012, 10:54 PM | #21 |
Re: Vin Number help
if you have the number i can tell you the color mike
01-25-2012, 08:34 AM | #22 |
Re: Vin Number help
check out tthe threaad on the dd number there is a vin similair to yours mike
01-25-2012, 10:03 AM | #23 |
Re: Vin Number help
I passed on it after offering him 250, 250 was too much IMO, thanks anyways. I did read up on the DD though and date code makes sense.
