01-22-2012, 02:11 PM | #1 |
12 bolt rear 3.73 gears
Have a set that I purchased here and did not use because I also found a set with a posi that I ended up using instead.
These are used with carrier and bearings, races, shims etc, One ring tooth small chip outer edge(small) should not affect operation at all. The carrier is open. $35.00 + actual shipping. Can get pics if any one interested. Thanks Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
01-22-2012, 05:29 PM | #2 |
Re: 12 bolt rear 3.73 gears
3 or 4 series?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-22-2012, 08:05 PM | #3 |
Series 4 I believe. Series 4 goes from 3.73 to 4.10.
I also have a Open Carrier Series 3 2.76 to 3.42, I believe. That would be just the carrier. The original post is for both carrier and gears. Thanks for replying. Ron
01-22-2012, 08:20 PM | #4 |
Rats! Thank bud
01-23-2012, 12:52 AM | #5 |
Can I see a picture that shows the chip?
01-23-2012, 11:46 AM | #6 |
Here is some pics
Ron
01-23-2012, 11:51 AM | #7 |
Couple more
Ron
02-18-2012, 10:54 AM | #8 |
If you still have the carrier and 3.73 gears can I have a shipping quote to
S9V 1Y4, Canada Thanks Josh |
02-18-2012, 10:59 AM | #9 |
Ok working now
Thanks for replying Ron Posted via Mobile Device
02-23-2012, 11:39 PM | #10 |
I have not forgot about you just been super busy. Thanks
Ron
02-23-2012, 11:45 PM | #11 |
Don't worry I'm not in a rush
